Not powering on starts led blinks 4 times then off
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Acer DAOZK6MB6D0
    REV: D
    It had a blown diode replaced it then it had few other resistors blown next to ic isl6251 replaced them and now on dc power supply 19v stable but drawing 1amp thats it not drawing any when i presspower light blinks 4 times
    The resistors was showing hot so this is why i replaced them with the similar ones.
    Using thermal camera i can se the isl6251 ic getting heated up look at the image.
    Please tell me what to do.
    Re: Not powering on starts led blinks 4 times then off
    What are the values of the blown resistors?
    What pin of the IC those blown resistors connected to?
    What resistance do you get on the VCC pins of the IC with ref. to GND?
    What resistance with ref to GND do you get on the output end of those blown resistors?
    Resistor get hot if the load side is shorted or has very low resistance so more current will flow and causes it to heat up beyond its rating.
    • Stevie2001
      • Apr 2018
      • 183
      • irland
      I will get back to you with more info values.
      Voltages of pins and resistor and where the resistor belong to.
      Do you think changing the ic might fix this.
      The value on blown resistor is
      01x
      89c
      Caps x1 10ohm i think
      2r2 replaced with biger 2r2 sinc i salvaged that
      30x replaced with 20 ohm
      1 dioid near ac jack blown value pj9n6 replaced with same size of diode not value still power is flowing so am assuming its ok.
      If you check shematic maybe you will se what it connects to.
        • 20387
        If you have the schematic upload it.
        • Stevie2001
          • Apr 2018
          • 183
          • irland
          When i press power orange light blinks 4 times nothing else happens.
          Acer 5739
            Where is the schematic?
            BTW, you need to provide the damaged parts designators (I.E. R123, C123, D123, L123, etc.), without it you cannot tell which part is which.
            • Stevie2001
              • Apr 2018
              • 183
              • irland
              Pd10
              Pr22
              Pr26
              Pr21
              Pc24
              Pr24 use to get heated along side pu3 now replaced these they ok not heating only pu3 heating up with thermal and with finger cant feel it
                • 20387
                The cap at PC24 wants replacing.
                Quanta ZK6 , page 31 .
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  Can i ask is this why when i press power the orange light blinks 4 times nothing happens after that is that the part causing it
                  Pc24 shows in shematics 01uf 50v
                    • 20387
                    I'm looking at your picture, it looks like the pad is damaged under pin 1 of pc24 and pin 2 isn't soldered down ? .
                    • Stevie2001
                      • Apr 2018
                      • 183
                      • irland
                      I fixed that up.
                      After doing all caps resistors when i connect dc power supply 19v ok with 2amps without battery now when i press power button the orange light blinks 4 times then off.
                      Nothing else turns on no fan nothing i should be expecting blue light.
                      When also when i click power button the amp remains at 2 on dc power supply its not drawing any amps when i click power.
                      Can that ic be the main problem to all this
                        • 20387
                        "30x replaced with 20 ohm"
                        "1 dioid near ac jack blown value pj9n6 replaced with same size of diode not value"
                        You should replace parts with the same value`s. Heres the datasheet for the ISL6251 , look at page 2 and page 8
                        • Stevie2001
                          • Apr 2018
                          • 183
                          • irland
                          Yeh thanks was usfull
                          I will get the original parts ordered.
                          For example if a resistor marking is 30x does that mean i only have to get that? In datasheet it shows the ohms and i thought as long its same part and ohm it should work?.
                          How sill i test isl6251 if its bad or good even thermal showing heat.
                            • 20387
                            "For example if a resistor marking is 30x does that mean i only have to get that? In datasheet it shows the ohms and i thought as long its same part and ohm it should work?."
                            The resistor marked 30X has a 1% tolerance .
                            http://www.marsport.org.uk/smd/res.htm
                            I`d replace the isl chip,diode and resistors.
                            • Stevie2001
                              • Apr 2018
                              • 183
                              • irland
                              Sir i will but i wanted to say since i havnt got new ic yet what if i take that ic out will it power on?
                              Video
                              http://sendvid.com/s5hpysqf
                              • Stevie2001
                                • Apr 2018
                                • 183
                                • irland
                                I was thinking about maybe other component maybe heating the ic so what are the main voltages am looking for
                                19v 3.3v 5v
                                • Stevie2001
                                  • Apr 2018
                                  • 183
                                  • irland
                                  Pq29 pq28 pr135 phase 1.05v missing.
                                  Guys if you can check am having suspicion on part pu7
                                  As it is near the power jack and giving voltages read below.
                                  Pin1 00.0v should be +1.05v shown on boardview
                                  Pin3 03.6v should be 1.05v_FB
                                  Pin4 1.94v Boardview shows HWPG_1.05v
                                  Pin8 00.0v should be LGATE-1.05V
                                  Pin11 02.0v should be PHASE-1.05V
                                  PIN12 02.1V should be UGATE-1.05V
                                    • 20387
                                    Does the battery charge light come on if you put the battery in . If the battery charges up ,try turning on with just the battery .
                                    • Stevie2001
                                      • Apr 2018
                                      • 183
                                      • irland
                                      It blinks once then no more and using thermal i can se the left side of battery heats up.
                                      By the way the reading values on pu7 does it seem ok or not sir.
                                        • 20387
                                        just replace the isl and other parts, take it from there .
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
