HP Product Family lookup for Motherboard tattoo
  • expertpc
    • Jan 2016
    • 11
    Good morning,
    We have been looking for a list of motherboard product family codes for HP laptops so the replacement boards can be programmed.
    The laptop in question is an HP PAVILION X360 - 15-BR080WM with Product Number 1KT65UA. Using the Bios Configuration Utility the Serial Number, Product Number and Manufacturing Mode have been updated but the Product family is blank and I have found no documentation on this field, and it gives an error each boot saying the family is invalid or missing.
    Does anyone have any ideas? I included a config file as an example. Thanks all!
  • expertpc
    • Jan 2016
    • 11
    Re: HP Product Family lookup for Motherboard tattoo
    System family, not product sorry
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      GUID and UUID must valid. read form sticker on bottom of laptop, under battery or on ram slot (very small sticker)
      Im Back... sort of...
      • eddie563
        Lenovo ThinkPad T14 Gen2 Motherboard Replacement - Error 2202 Product Name Incorrect.
        by eddie563
        Hi All,
        Hoping to get my final issue over the line.
        Had to change my dead motherboard out, found the answers to my my other issues here to update the Serial number UUID etc using the LenovoUone tool here but I am still left with the error in the subject line.
        when using the tool to update the eprom its seeking a hexadecimal code to update the product name. would anyone happen to know where I can source it?
        thanks in advance.
        11-25-2024, 07:30 AM
      • glovecaps
        Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
        by glovecaps
        I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
        My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
        The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
        11-25-2024, 04:23 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
      • sikocan
        Lenovo X1 Carbon 9th Gen Black Screen
        by sikocan
        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
        SN: PF3G1REP
        MODEL: 20KW-00J1AU
        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
        06-24-2025, 09:01 PM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
