Dell inspirion 1545 WiFi problem
  • akande
    • Dec 2017
    • 278
    • Nigeria
    I have dell inspirion 1545 that connect my WiFi fine but cannot surf the Internet, I have formatted it twice , change WiFi card, drive the WiFi with a working driver from Dell support no luck ,am confused need someone to assist on this
  • akande
    • Dec 2017
    • 278
    • Nigeria
    Re: Dell inspirion 1545 WiFi problem
    I need someone help on this issue pls
    • KillerFlash
      • Apr 2018
      • 8
      • Phillippines
      Check your IP address sir...
      • KillerFlash
        • Apr 2018
        • 8
        • Phillippines
        Check your date and time if its accurate if its not change it, and change your CMOS battery.
        • perzyk23
          Dell Inspirion 15-5567 LA-D801P - power problem
          by perzyk23
          Hello!
          I have problem with Dell Inspirion 15-5567
          CPU I7-7500U
          GPU AMD
          Laptop has won't turn on.
          The U1 chip it was burned and i replace him but laptop it is still death.
          I measured the values on the coils with RAM inserted:
          PL1401: 42Ω
          PL605: 10Ω
          PL603: 14,6Ω
          PL100: 0,8Ω
          PL101: 62Ω
          PL700: 13,4 mΩ
          PL501: 3Ω
          PL601: 25,8Ω
          PL1103: 22,4Ω
          PL1102: 22,7Ω
          PL200: 267Ω
          PL300: 0,8Ω
          What can I do to repair this motherboard?
          03-27-2025, 09:18 AM
        • toti24
          (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
          by toti24
          dell precision m4600 laptop
          i7 2760qm
          8gb ram 750gb HDD
          intel hd 3000 integraded and nvidia quadro 2000m
          pleasea bear with me english isnt my language and ill try to be as clear as possible
          note i live in mexico in a very small town..
          thank you.
          laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
          the brick happened when i was installing win 10 using usb.
          used rufus and officia microsoft.iso
          it finished copying files from usb...
          03-06-2022, 08:39 PM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
        • Achille15
          Dell N5110 problem
          by Achille15
          so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
          03-29-2025, 04:41 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
