Dell Inspirion 15-5567 LA-D801P - power problem
  • perzyk23
    • Mar 2017
    • 31
    • Poland
    Hello!
    I have problem with Dell Inspirion 15-5567
    CPU I7-7500U
    GPU AMD
    Laptop has won't turn on.
    The U1 chip it was burned and i replace him but laptop it is still death.
    I measured the values on the coils with RAM inserted:
    PL1401: 42Ω
    PL605: 10Ω
    PL603: 14,6Ω
    PL100: 0,8Ω
    PL101: 62Ω
    PL700: 13,4 mΩ
    PL501: 3Ω
    PL601: 25,8Ω
    PL1103: 22,4Ω
    PL1102: 22,7Ω
    PL200: 267Ω
    PL300: 0,8Ω
    What can I do to repair this motherboard?
  • mon2
    • 14500
    For starters:
    PL501: 3Ω
    is too low. This is the +1.8VALWP rail. Locate the solder blob @ PJP502. Use flux and separate the 2 sides of this solder blob. Then test the resistance to ground on each side of PJP502 PCB pads. Which side is showing this short?
    Producer side (PL501) or consumer side (load)?
    Same for:
    PL100: 0,8Ω
    which is linked to +3VALWP and also the PCH. The PCH / CPU may be shorted.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      A Short/Low resistance on 1.8v rail couled with 3.3v rail=DEAD SOC
      • perzyk23
        • Mar 2017
        • 31
        • Poland
        Originally posted by mon2
        For starters:
        PL501: 3Ω
        Same for:
        PL100: 0,8Ω
        Please look at the picture.
        I have 3 Ohms on the bottom pad. I have a boardview from LA-B802P (similar to my board). The bottom pad is connected to the CPU but if I check the resistance with the RC137 resistor then I have 1.13 kOhm. On the other resistors next to it it is also high. The R137 resistor itself has 1.13 kOhm. It's possible that these values ​​are too small for this processor anyway. The top pad is 30 kOhm.
        PL500: 30 kOhm
        PL100 still has 0,8 Ohm but it connects to the PU100 system. Pin 6, 19, 20. I'll check if that's the problem here.​
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • remizbushka
          Dell inspirion 5775 bios "Unlock Setup fail"
          by remizbushka
          Hi sirs. please help
          Dell Inspiron 5775 bios locked "Unlock Setup fail"
          After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
          What I did:
          I read the bios dump.
          Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
          03-24-2025, 09:07 AM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • IvanAndreevv
          Dell Inspirion M5010
          by IvanAndreevv
          Hello. I have a Dell Inspirion M5010 with S/N J8NBXMI with board 48 4hh06 011 with the following problem:
          Many attempts are needed for laptop to boot up, but when it does, everything works normal after that.
          I think my BIOS is corrupted. Could someone please provide a working file for that laptop?
          Posting the old one in the attachments.
          BR!...
          02-28-2024, 10:30 AM
        • jonyhdtv
          Help me with unlock Dell Inspirion 13 7348
          by jonyhdtv
          please help me remove password in BIOS in Dell Inspiron 7348
          BIOS A05
          System Disable
          [299E71BEA1A57DCD]
          Service Tag
          [C34YH52]
          I don't know what method to use for this model.
          01-29-2025, 07:59 AM
