Asus X555L backlight shuts off when on battery
  • sakalaz
    • Sep 2019
    • 31
    • Lithuania
    Re: Asus X555L backlight shuts off when on battery
    Hi guys, same issue here (I think)
    so far I have noticed two things:
    1. BL_EN signal going to the LCD is 2.6v not sure if this is normal nevertheless backlight comes on when plugging the charger.
    2. AC_BAT_SYS going to LCD when on charger is 19V and after disconnecting the charger it drop to 7.6v (battery voltage). My assumption is that this is the main issue for the backlight not turning on. I would expect the voltage to be in range 12v-19v
    Not realy sure where to go from here? Charge controller IC?
    • sakalaz
      • Sep 2019
      • 31
      • Lithuania
      Just had a look at LCD panel specification that I have (Innolux N156BGE-L31)
      Basically all the signals going to the pannel are correct and within the specification.
      From specification:
      1. BL_EN - backlight enabled voltage range 2.4-3.6
      2. Pin38, Pin39, Pin40 - backlight voltage range 6v-21v
      So... it must be that LCD logic board that is faulty. Could be the backlight DC boost circuit. I will be checking that today
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        It would be interesting to see how/if you manage to solve this issue. This was slightly before I got really into component-level board repairs, so I lacked the required skills and knowledge to work out stuff like this on my own.
        Wattevah...
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          From specification:
          Just replace the coil(marked 100) near backlit IC on led panel. Though weird but works. had this same issue on asus.
          See my thread
          https://www.badcaps.net/forum/showthread.php?t=76823
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Hm...wonder if it works on this model too. Guess it depends on what panel you get in your laptop, since I imagine they may differ even between identical models.
            Wattevah...
            • RethoricalCheese
              • Mar 2013
              • 1518
              • Estonia
              #26
              Yes, it seems to be same on all the Asus xx55y models with this fault. It took two hours of research surfing russian forums to find out about it. (And I don't even speak russian )
              • sakalaz
                • Sep 2019
                • 31
                • Lithuania
                #27
                So I went through the backlight circuit without having a datasheet for CM509A chip and couldn't find anything obviously wrong...
                Just replacing the coil sounds not very convincing. Coils are passive components so it is uncommon for them to go bad unless they run hot or windings get shorted. Those LCDs that get "fixed" by replacing the coild could most likely be the cause of heat applied to driver chip or the diode near it (remember graphics chips, tantulum capacitors...) Nontheless I will try replacing the coil as a last try.
                Just found someone stating that MP3388 is a direct alternative for CM509A. I will have another galnce at the board now with this information at hand.
                Datasheet for MP33388 https://cdn.badcaps-static.com/pdfs/...f57cd8ef3f.pdf
                Orderd an inductance meter from aliexpress and a pair of CM509A and MP3388 chips to play with.
                This coil is 10 uH I think? Will be interresting to measure it
                so next steps:
                1. Take the coil off and measure it
                2. Change a backlight driver chip to new one
                3. Change a backlight driver chip to alternative (MP3388)
                4. Change the coil
                • RethoricalCheese
                  • Mar 2013
                  • 1518
                  • Estonia
                  #28
                  Just an hour ago had another Asus with the same problem. Replaced coil, got it working.
                  Maybe it is just underdimensioned thus running on its limit and will start acting up after a few years of use.
                  • sakalaz
                    • Sep 2019
                    • 31
                    • Lithuania
                    #29
                    Is it a 10 uH coil? You take then from a donor PCBs or do you buy them?
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      #30
                      Since I have a pile of scrap donor displays, I get them from there.
                      Yes, marking 100 = 10uH.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        #31
                        So was your problem similar to mine where there's backlight on AC power only ? Wish I had known of this trick at that time too
                        Wattevah...
                        • RethoricalCheese
                          • Mar 2013
                          • 1518
                          • Estonia
                          #32
                          Yes, exactly the same problem. Seems to be a problem with Innolux panels.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            #33
                            Sorry for the late reply. Given that the coil which causes the backlight to shut off when the laptop is running on battery is on the panel itself, it means the problem could also be solved with a new panel entirely, can't it ?
                            I can understand why nobody would bother to check with a replacement panel, because they'd plug the adapter in, see the picture come on screen nice and crystal clear and think "nope - display must be fine", but it isn't !
                            Is the backlight driver for these displays located on the panel itself ? I know Louis Rossmann talks about backlight circuits a lot and they're always on the laptop's board and not in the panel itself. It means the LVDS cable carries "B+" to the display which is then stepped up to drive the LEDs...I was curious what sort of voltage one might expect to see on the LVDS connector itself. On Macbooks, the LED voltage itself is present there, which is pretty high.....and dangerously close to the signal lines for the display
                            Wattevah...
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              A new compatible panel does solves the problem in asus but why replace it if a simple coil replacement solves the problem. The backlit driver is located on the panel itself just near the backlit connector on the screen.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Originally posted by Dannyx
                                has stopped working
                                That's the dumbed-down Windows error message, since Vista, meaning it has crashed with an invalid page fault (called an access violation) or another application-related exception detected by Windows.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #36
                                  I had no idea what you were referring to, since you didn't include my full quote, so I looked back and found out I was talking about OpenBoardView not working for me Since then, I actually found a different one called OpenBoardViewER and that works perfectly No idea where it came from TBH, but who cares as long as it does its job.
                                  Wattevah...
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    I quoted the "X has stopped working" Windows pop-up.
                                    Arc A770 16 GB
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      #38
                                      Yeah, it's been a while and I forgot WHAT was not working
                                      Wattevah...
                                      • mellbo
                                        • Feb 2017
                                        • 4
                                        • romania
                                        #39
                                        Hello guys. I also have this problem with Asus TP550LD. I would like to order that coil from TME, but I need some small help. I don`t know about curent of the coils. Any guys with TP550LD can confirm about fix with replace the coil in nearing CM509A ?
                                        • Dannyx
                                          CertifiedAxhole
                                          • Aug 2016
                                          • 3912
                                          • Romania
                                          #40
                                          Originally posted by mellbo
                                          CM509A ?
                                          Is this a capacitor on the LVDS board of the panel ? Just curious...I don't have a panel on hand unfortunately...
                                          Wattevah...
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • dhenion
                                            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                            by dhenion
                                            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                            The original board was:
                                            ASUS X510UNR REV 3.0 A
                                            The replacement board is:
                                            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                            01-30-2024, 01:45 PM
                                          • rob777
                                            Asus TUF won’t run off battery
                                            by rob777
                                            I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                            I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                            Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                            Thanks....
                                            05-27-2025, 07:07 PM
