Toshiba c850 black screen with caps lock and numlock working please help
  • khaledalhanafy
    • 7
    • Mansoura
    I have in my office many laptop c850 with the same problem
    And Iam buyed wds 620 rework station but I want help
    How can I know which chip is falling amd2016-0810028 or slej8e it must chang it or what is the solution please
  • evgenigenko
    • Feb 2018
    • Bulgaria
    Re: Toshiba c850 black screen with caps lock and numlock working please help
    graphical chip is 216-0810028, but before you change it, i suggest trying just to reflow it, and see if there is picture, then you can try replacing it.
    Other method you can use to test the video chip is measuring the resistance of the chip to gnd. if it is more than 5-10 ohm most likely is failing...
    please leave feed back after you try some of the methods.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Definitely AMD chip, intel chipset (despite getting hot) has no play in this issue.
      A working TV? How boring!
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • sigmeyer
        Toshiba 50UL4B63DG faulty screen?
        by sigmeyer
        I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
        08-30-2025, 08:13 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • zlr8r
        HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
        by zlr8r
        Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
        To begin with, this laptop was dead-dead.
        Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
        • am getting white power led
        • 5-long-flashes on CAPS Lock and NUM lock
        • then, fan full speed
        • CPU heats up some (smaller die PCH, does not)
        • always constant black screen no matter what's tried
        • no USB recognition
        • no HDMI output
        this is as far as I can get with it and not sure where to inspect next ?
        I tried...
        03-27-2024, 03:13 PM
