compaq presario c700 battery repair technic
  • russell1981
    • Jan 2012
    • 32
    • bangladesh
    how can i repair this Compaq presario c 700 battery?because i did visit to my local shop for this model.....they said this is so old model.so my final and last hope is badcaps.net!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: compaq presario c700 battery repair technic
    https://www.aliexpress.com/wholesale...o+c700+battery
    • russell1981
      • Jan 2012
      • 32
      • bangladesh
      THNX....thread is now closed.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        Hp Compaq Presario C700 C702TU GL-A3732P LA-3732P R10-0921 Board View
        Hp Compaq Presario C700 C702TU GL-A3732P LA-3732P R10-0921...
        10-03-2024, 05:03 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • LukeDavis
        Compaq Presario F700 - DA0AT1MB8H0 -Not turning but charges the battery
        by LukeDavis
        Hello there!.
        I've recently aqquired a lot of older computers I wish to learn and fault find with.
        Among the machine there are 5 defective machines - 4 of which with motherboard issues.
        This Presario doesn't turn on but the battery indicator and charging port light up, the port doesn't tell me anything as it lights up even without being attached to the motherboard.
        The fact the battery charges proves at least 18v is getting to all the nessesities.
        The laptop has an AMD Athlon 64 X2 and a small Nvidia chip with the...
        02-12-2024, 01:42 PM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
