da0r75mb6cd0 REV: C mising +1.8V VGA
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Hi guys
    got here a problem with this MB da0r75mb6cd0 REV: C laptop starts up but no image found out missang voltage
    PL26 0v
    PL7 0V
    schematics page 43 VGA +1.0V VGA & +1.8 VGA
    PU14 IC
    PIN 1 0V
    PIN 2 0V
    PIN 3 0V
    PIN 4 0.9V
    PIN 5 0V
    PIN 6 0V
    PIN 7 0V
    PIN 8 3V
    PIN 9 3V
    PIN 10 3V
    PU2 IC
    PIN 1 0V
    PIN 2 0V
    PIN 3 0V
    PIN 4 0.9V
    PIN 5 0V
    PIN 6 0V
    PIN 7 0V
    PIN 8 5V
    PIN 9 5V
    PIN 10 5V
    schematics
    https://www.badcaps.net/forum/attach...6&d=1409168384
    need help
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: da0r75mb6cd0 REV: C mising +1.8V VGA
    If i give required voltage from power supply to PL 26 & PL7 what will happen ? PCH & VGA chips gets heat does it mean Vin ok for this 2chips?
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      If you do that, it is possible that the GPU chip gets damaged. Leave PU2 and PU14 alone. they seem OK. first, you have to check if the laptops has cpu_core voltage on PL11 or PL12.
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Ok thanks for the reply I check the voltage on
        PL 11 +Vcc core 1.8v
        PL 12 +Vcc core 1.9v
        Found out another missing Voltage
        Pl 23 +Vga core 0v
        Pl19 + Vga core 0v
        IC chip PU8 is connected to the coils I check the mosftes related to the colis 19v in ok !
        PU8 do have to check DRVL 1 & DRVL 2 out puts ? Or any other pins to to check any test points in this ic ?
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          now you have to find a shop that has another CPU which is compatible to this mainboard. then, ask them test this mainboard with a healthy CPU. or test your CPU on another mainboard.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Ok i will do it and let you know soon
            • Techtiger
              • Oct 2014
              • 1602
              • france
              I I tested with working CPU but still no image
              PL26 0V page 42
              PL 7 0V
              PL 19 0V page 42
              PL 23 0V
              To get gate pass ( PU8 IC ) page 42
              DRVH1 0V PQ19
              DRVH2 0V PQ19
              DRVH3 0V PQ20
              DRVH4 0V PQ20
              Do you need Pin 1 PU8 to get Gate V (pin1-EN) is it a voltage or signal?
              DGPU EN
              Do you need Pin
              42,43,44,45,46,47 PU8->GFX CORE to get Gate V is it a voltage or signal?
              What is SW1 SW2 in PU8? pin34/37
              and what is VID pin 42.43.44.45.46 PU8 voltage or signel ? is this also need to give the gate passevto DRVH1/1 DRVH 2/2 ?
              All the rest voltage I have given color's are ok
              as for PU14 IC page 43
              Pin 5 EN 0V or signel ? (DGPU EN)
              and for PU2
              need help from all bad cap community
              thanks in Advance
              • piernov
                • Jan 2016
                • 4435
                • France
                DGPU_PR_EN should be 3.3V for the VGA voltages to come up. This signal appears when the BIOS starts running.
                Pin 42-48 of PU8 set the output voltage for VGA_CORE. You can take a look at the table on page 42 to know the output voltage depending on the state of those signals. But you must get DGPU_PR_EN first anyway.
                Check the APU_RST# signal. It must be high (above 1V) for the CPU to turn on and for the BIOS to start running. If APU_RST# is above 1V, try to flash a working BIOS. (back it up first)
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  merci beaucoup pour votre aide j'apprécie
                  thank you very much i wiil do it and thanks for the OpenBoardview file
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    i check the APU_RST# signal but U8 is not inclued but
                    Pin 1 1.5v with out IC
                    Pin 2 DNG
                    Pin 4 0.4V
                    Pin 5 4V
                    Pin 6 0V
                    R241/R235 not include but have 1.5V
                    what if i give a jumper 3.3V to PU8 Pin 1 DGPU_PR_EN what will happen will the IC blown out ?
                    i will flash BIOS to give a try
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      If you jump it, some component will probably get damaged.
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        Thanks Caspian
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          Guys missing voltage solved after flashing bios MB working fine
                          Thanks piernov & Caspian
                          • chaos-theory
                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                            by chaos-theory
                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                            03-14-2025, 05:37 PM
                          • arabex21
                            Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
                            by arabex21
                            Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
                            I have a problem with this configuration:
                            ASUS PRIME B450M-A
                            RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
                            When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
                            09-19-2024, 03:05 AM
                          • master3112
                            Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
                            by master3112
                            I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
                            UT5 pin 3 (SNK_PS_EN) =0V
                            RPT3 Pin1+2 LDO 3V3 present
                            I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
                            08-02-2025, 12:30 PM
                          • Shobos
                            Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                            by Shobos
                            Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                            So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                            NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                            Any help is welcome. Thanks !
                            07-29-2025, 03:53 PM
                          • JohnML1975
                            LG 49UK7550PTA - after couple of hours screen starts to blink
                            by JohnML1975
                            Hello Forum team
                            Have this TV; searched for the model and could not anything so thought I would share in here
                            Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
                            Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
                            So I removed the covers, and could not see anything visibly
                            Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
                            07-25-2025, 10:48 PM
