Macbook Pro 17 2011 problem.
  • quic307
    • Jun 2015
    • 255
    • Greece
    Hello friends and happy new year,
    I have a problem with a Macbook Pro 17" 2011, as you can see the photo.
    The problem it's not GPU or vga RAM, I change the chipset and VRAM but same isswe.
    Has anyone found the same problem... and fixed it?
    Thank you in advance.
  • basic
    • Oct 2017
    • 229
    • 86357289244
    Re: Macbook Pro 17 2011 problem.
    if not GPU then is screen ..
    • piernov
      • Jan 2016
      • 4437
      • France
      I pretty sure this is a GPU problem and the "new" GPU is an old dead one that was rebadged and reballed.
      OpenBoardView โ€” https://github.com/OpenBoardView/OpenBoardView
      • cacla
        • Apr 2015
        • 442
        You check the rails on vga ram to gpu some time they are oxidized.
        i have a simaler problem on one acer i replace gpu and vga ram and the problem was in the rails on vga ram to gpu.
        • quic307
          • Jun 2015
          • 255
          • Greece
          Of Course there is no screen problem ... I was check it with external too.
          I have two suppliers where I buy chipsets, so I try 4 different chip new +2016. Same problem.
          There is no oxidized, I guess the problem is with rails or something else but I cant find it...
          • cacla
            • Apr 2015
            • 442
            Check the rails under mikroskop
            • dellxps15
              • Feb 2014
              • 1591
              • italy
              power pc with script to enable intel vga only and check if it's the same problem. if yes we'll focus on pch lvds line, otherwise ati lines.
              • quic307
                • Jun 2015
                • 255
                • Greece
                I check it and it's ati lines. Now what I must to do? To check any line and all parts one by one?
                NOT EASY ...
                • inspirim
                  • May 2013
                  • 282
                  • Italy
                  controllare i condensatori smd sotto la gpu
                  • quic307
                    • Jun 2015
                    • 255
                    • Greece
                    I agree with you, but which caps are the problem?
                    I try with the 100nF, but same issue.
                    Have you ever solved that issue?
                    • fludor
                      • Nov 2015
                      • Belgium
                      Can you please share the password of the board view archive?
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue โ€“ Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ€” hoping someone here can shed some light.
                        ๐Ÿ›  Original Issue
                        The machine initially wouldn't negotiate 20V over USB-C โ€” stuck at 5V.
                        โš ๏ธ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • psdavid65
                        Macbook Air A1466 820-3437-B Booting Problem
                        by psdavid65
                        I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                        06-20-2024, 12:27 AM
                      • Skrndelj
                        Apple Macbook Air M1 A2337 Trackpad problem
                        by Skrndelj
                        Hello all,
                        I am repairing a Macbook A2337 and i have a problem
                        The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                        When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                        I inspected the whole board and everything seems fine.
                        Can anyone help me as i didn't fiddle with trackpad...
                        06-11-2024, 04:26 AM
                      • sdogs
                        Macbook Air 2020 A2179 820-01958 battery problem?
                        by sdogs
                        I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
                        After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
                        I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
                        Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
                        02-08-2024, 08:00 AM
                      • brockauly
                        Macbook M1 A2337 EMC 3598 weird battery charging problem
                        by brockauly
                        Hi guys,
                        If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                        Then if I unplug the charger and plug it back, it won't charge anymore.
                        In the first case, main voltage is regulated at ~12.5V and charges the battery.
                        After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                        After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                        I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                        02-05-2025, 10:51 AM
