Hp15 problem
  • akande
    • Dec 2017
    • 278
    • Nigeria
    Hp15 problem
    hello friends
    i have hp15 keep corrupting all operating system installed on it {win10,8,7} have tried all but once its installed the os will corrupt, need someone to guide me to solve problem
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Hp15 problem
    Try to change HDD and reinstall OS on the machine.
    • akande
      • Dec 2017
      • 278
      • Nigeria
      Re: Hp15 problem
      thanks for quick reply, but have change three different good hdd, still no luck
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Re: Hp15 problem
        In addition to Hdd, RAM, CPU, GPU, and PCH can be faulty too.
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
        • Exim
          ASRock N100M looking for Bios
          by Exim
          Help request:
          I am trying to solve a problem with an ASRock N100M board, it seems to be stuck in an infinite loop in POST (all details and a short video here). External flashing of the available bios versions does not solve the problem.
          I don't know if this is a hardware problem or possibly a corrupt ME region in the bios. Therefore I am looking for both
          - Bios file with clean ME region
          as well as
          - Schematic and Boardview file
          I have a working programmer, a dump of the bios chip and the bios file from the manufacturer ...
          04-07-2025, 11:14 AM
