ASRock N100M looking for Bios
  • Exim
    • May 2011
    • 64
    Help request:
    I am trying to solve a problem with an ASRock N100M board, it seems to be stuck in an infinite loop in POST (all details and a short video here). External flashing of the available bios versions does not solve the problem.
    I don't know if this is a hardware problem or possibly a corrupt ME region in the bios. Therefore I am looking for both
    - Bios file with clean ME region
    as well as
    - Schematic and Boardview file
    I have a working programmer, a dump of the bios chip and the bios file from the manufacturer ...
  • hoaca388
    Badcaps
    • Jan 2022
    • 12316
    Originally posted by Exim
    Help request:
    as well as
    ASRock N100M
    • Exim
      • May 2011
      • 64
      Thanks for the file. But this seems to be the original unmodified 1.10 bios from ASRock. Flashing this or the original 2.01, which is also available at ASRock, does not solve the problem, unfortunately.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12316
        Check hardware problem.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
