Lenovo 5250 led screen backlight voltage
  • 6ot4hr
    • Oct 2014
    • 87
    • Croatia
    Hello, a friend brought Lenovo 5250 with broken lcd screen. Backlight fuse was blown and one ceramic cap shorted to ground... Anyhow, new screen will be replaced but there is one thing bothering me now. I reckon i saw 19V on lvds cable going to backlight fuse, but now when screen is disconnected it only shows 11.8V.
    So a question, what voltage should be present for backlight 11.9V or 19V, i think something else might be off?
    LCD Model is LG LP156WH4.
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Lenovo 5250 led screen backlight voltage
    If it is on(19v) charger then it must 19 volts and it is on battery only so ma be 11.8v.
    • 6ot4hr
      • Oct 2014
      • 87
      • Croatia
      Hah, yeah, when on battery it gives 12V to inverter input, and when on charger than it is 19V...
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
      • turmix
        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
        by turmix
        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
        During another reassembly, I made a mistake, and...
        01-29-2024, 03:48 AM
      • FallenOne008
        Asus G712L No Screen Backlight
        by FallenOne008
        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
        03-31-2025, 08:27 PM
      • EffiSon
        Lenovo Y50-70 - LA-B111P Rev:1A Flickering laptop screen after shorten the R205 resistor/ backlight restoration ?
        by EffiSon
        Hi. Could anyone on the forum help me find the cause of the problem?
        The board is LA-B111P Rev:1A comes from Lenovo Y50-70.
        I have a identified the damaged R205 resistor, and connect a jump wire over it So it restores the backlight but causing strange problems
        1. With Battery ONLY plugged in laptop works fine
        2 .With Charger ONLY plugged in laptop works fine as well
        3. Connecting both battery and charger at the same time shows a strange flickering screen. The flickering is not constant, it is completely random (and I think it depends on the load
        01-29-2024, 04:03 PM
