Samsung NP350E5C sometimes opens after 2 minutes of no screen
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    Hello friends! I am an experienced tech but have never seen that kind of behavior. A laptop came for regular checkup and maybe a new disk complaining also for wifi shutting down many times. I formated it with windows 10 and got it updated fully and all good. Gave it to client only to get it back after 2 days. I tried to test it but after rebooting sometimes it got stuck with this unusual problem.
    It sometimes opens after 2 minutes of no screen at all properly on Windows. I can restart it properly but if I press shutdown it refuses to start or it gives a complete black screen no light nothing and after 2-3 minutes it is magically revived. Sometime it does not start at all though. Changed RAM and slots, removed wifi and touchpad, even keyboard doing the same thing. Trief to reflash BIOS from Samsung utility but refuses cause it is the same version. I do not have a BIOS programmer still... Currently I am trying to mess with secure boot and UEFi... What do you think guys??
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Samsung NP350E5C sometimes opens after 2 minutes of no screen
    If the screen stays black for a couple of minutes then you see the BIOS POST screen, then chances are it is a BIOS issue. You need to flash a full dump using an external programmer.
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      Hmm yeah thats what I am thinking. I mean I tried to do a BIOS flash from Windows downloading the latest flash utility but was stuck at reading bios and then freezing... I guess I will buy that programmer after all. Should have done that sooner... I wonder if that indeed fixes the problem!
      • petehall347
        • Jan 2015
        • 4425
        • United Kingdom
        probably ms broke it with updates ..happens all the time so i hear on other sites .
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Might be me region corrupt in bios. However, you need a external programmer to fix that.
          • Dimitrios
            • Nov 2013
            • 127
            • Greece
            Are the updates able to distort the BIos chip?? Wow...
            One idea came to mind. I have a carprog lying around with 4 pin soic clip! Can I use it? How to identify the EEPROM chip code?
            • piernov
              • Jan 2016
              • 4435
              • France
              Nope, won't work. In this screenshot I see support for "24C" type ROM, which are I²C. BIOS ROM are SPI, usually "25Q". However if you have a Raspberry Pi it is able to flash SPI ROM using flashrom. (you may be able to do it with an Arduino too).
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                Yes you are right my Bios chip is also 25LC...Bought it for airbag reset but proved useless. I ordered a TVP2588U+ Bios Programmer locally so it arrives faster. Should I reprogram both chips?
                • Dimitrios
                  • Nov 2013
                  • 127
                  • Greece
                  Got the programmer but I do not like its quality and has very little options on chips numbers. However I managed to program one eeprom MXIC MX25L1605D but same symptoms applies and not even booting once. At least before it booted after 6-8 times...
                  • Dimitrios
                    • Nov 2013
                    • 127
                    • Greece
                    BIOS file has a little bigger size on disk (2MB) and my programmer wont let me flash. Keeps saying excess data dropped... What can I do?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Is there any detect or auto detect option in the software interface of your new programmer??? If so then use that option.
                      • Dimitrios
                        • Nov 2013
                        • 127
                        • Greece
                        The problem is that the size is a little higher than 2 MB....
                        Thanks for replying!
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          probably u need to clean me region and reprogram bios file.
                          • Dimitrios
                            • Nov 2013
                            • 127
                            • Greece
                            A quick reflow on the northbridge and flashed both bios chips but still the same. No video black screen and only power button lit...
                            • dellxps15
                              • Feb 2014
                              • 1588
                              • italy
                              what nb it has ? if the small intel u need reball as reflow doesnt work most of the time.
                              • Dimitrios
                                • Nov 2013
                                • 127
                                • Greece
                                NB is 11 E239B323 SJTNV, Mobile Intel® HM70 Express Chipset
                                • dellxps15
                                  • Feb 2014
                                  • 1588
                                  • italy
                                  if u can try to reball it
                                  • foulou0238
                                    • Mar 2014
                                    • 109
                                    • France
                                    Hello ,
                                    i think that the probleme is from Me management you can tray to cleare ME before do any other tests .
                                    good luck
                                    • bohemian
                                      • Jun 2017
                                      • 9
                                      • morocco
                                      Originally posted by foulou0238
                                      Hello ,
                                      good luck
                                      can you explain more
                                      • foulou0238
                                        • Mar 2014
                                        • 109
                                        • France
                                        hello ;
                                        send me the Dump of your bios and i will try to clear the Intel ME for you .
                                        Best regards
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
                                          09-06-2024, 11:40 PM
