Samsung NP350E5C sometimes opens after 2 minutes of no screen
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    Re: Samsung NP350E5C sometimes opens after 2 minutes of no screen
    Oh awesome! Thanks! I attach the two files mine is the backup the other is the one that need to clear the ME!
    • foulou0238
      • Mar 2014
      • 109
      • France
      helo,
      how many chips did u have on your computer this one is EC i need both one EC and Main généraly the me is stored on Main !!
      the file that you sent dont have any ME.
      waiting ur replay
      • Dimitrios
        • Nov 2013
        • 127
        • Greece
        oh ok my bad. I sent the EC. Here is the MAIN
        • foulou0238
          • Mar 2014
          • 109
          • France
          hello,
          here is your file Cleared .
          i toke the other one not yours and clear it test and post résult
          • Dimitrios
            • Nov 2013
            • 127
            • Greece
            Awesomeeee! Will do first thing tomorrow morning!! Thanks a lot! Will let you know!
            • Dimitrios
              • Nov 2013
              • 127
              • Greece
              #26
              Did both the chips with your cleared files. Now I get a reboot loop. Starts and shuts off and again the same. Noticed that pins 7 and 8 got shorted on the mainboard cause of the heating cycles... I do not think that causes any problem check schematics please
              https://www.badcaps.net/forum/showpo...84&postcount=2
              • foulou0238
                • Mar 2014
                • 109
                • France
                #27
                Hello
                I do the clear from other files that you sent so if you want I can do clear from ur original files and not downloaded one !!
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  #28
                  shorted means they are grounded, while i think u are referring to as bridged, as 7-8 are same pin and that's not a problem at all.
                  ofcourse wich chip are u talking about ? bios or ec ?
                  • Dimitrios
                    • Nov 2013
                    • 127
                    • Greece
                    #29
                    You are right, they are bridged! Both of them!
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • Kiberge
                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                      by Kiberge
                      HI guys!
                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                      04-22-2024, 11:28 AM
                    • arbitarytwist
                      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                      by arbitarytwist
                      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                      03-01-2025, 01:16 PM
                      09-06-2024, 11:40 PM
