Lenovo G50-80 Turns on and off within 4-5 seconds
  • m1rc34
    • Feb 2020
    • Romania
    #41
    Re: Lenovo G50-80 Turns on and off within 4-5 seconds
    Has somebody solved this? I have the same issue
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3598
      • slovakia
      #42
      check resistance and voltage on CPU
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        #43
        ANSWER
        I KNOW I AM TOO LATE TO REPLY
        BUT THIS WILL HELP TO ANOTHER PEOPLE WHO HAS SAME ISSUE AND REPEATING SAME MISTAKE
        Q25 gate should be active low
        "SUSP#" SIGNAL WILL COME AND DEACTIVATE "SUSP" SIGNAL
        It mean when ground will come on the gate Q25
        Than only "20VSB" will release and activate +5VALW TO +5VS
        • Radio Operator
          • Jun 2016
          • 17
          • greece
          #44
          it was a mosfet 4483A failure mine problem
          • Solac03
            • Jul 2021
            • 12
            • Philippines
            #45
            Originally posted by qayyum786
            ANSWER
            hi sir what is the value of q25 ? i have the same issue and will try to change q25
            • Solac03
              • Jul 2021
              • 12
              • Philippines
              #46
              ok i have checked q25, correct me if i am wrong. when there is power drain side of q25 should have 5V ? i have measured gate pin of q25 give intermitent 5v, i noticed that when the power led turns on the voltage drops and goes back when power led turns off. To switch on q23 pin 4 (gate) should have 5v, so that pin 123(drain) of q23 will have +5vs. i have tested my board and q23 does not have +5vs. my board keeps blinking power led when adapter is plugged in, even if not switched on. also fan seems to spin a bit and stops. i don't really know if q25 is broken i have tested drain and source using diode mode seems to be fine. where does the SUSP# singnal come from ? the diagram has q26 but my board does not have q26.
              • Solac03
                • Jul 2021
                • 12
                • Philippines
                #47
                Up
                • lordgeny
                  • Apr 2016
                  • 223
                  • Italia
                  #48
                  i have the same problem but if i try to turn on 3 4 times then it starts
