HP 14, LA-A994P, charging light, power led on for 1 second when power button pressed
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: HP 14, LA-A994P, charging light, power led on for 1 second when power button pres
    now i see schematic. yes, but still "measure short to ground and voltage when it is starting on all big grey coils and capacitors"
    • iplaypty
      • Aug 2017
      • 47
      • FLORIDA
      Originally posted by ktmmotocross
      If it is starting, u have 3.3 ALW so u must have EC_ON
      find short to ground, low voltage /overload/, no voltage /not work/ or bigger voltage /burn/
      @ in schematic means that is not used
      Thank you!
      I did test on continuity mode to those caps (attached photos), they beep on both sides.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3610
        • slovakia
        Originally posted by iplaypty
        Thank you!
        beep is not short. short is under 4ohm. processor and gpu have low ohms so they beep
        how many ohms do u have?
        chceck for voltage on all big coils when starting
        u have SoC platform, so if something goes wrong, bad is mostly SoC IC
        • iplaypty
          • Aug 2017
          • 47
          • FLORIDA
          So even if it beeps on both sides, both sides have to be less than 4 ohms?
          • iplaypty
            • Aug 2017
            • 47
            • FLORIDA
            Sorry, I am learning a lot from you guys. Thank you!
            The ones close to the screen connector are less than 1 ohm on continuity mode, both sides.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3610
              • slovakia
              #26
              big coils i mean the big grey cubes.
              check voltages on they when u press power button. it must climbing. when not check for short
              • iplaypty
                • Aug 2017
                • 47
                • FLORIDA
                #27
                how?
                black lead on ground, red lead on coil +?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3610
                  • slovakia
                  #28
                  yes and same for short check
                  • iplaypty
                    • Aug 2017
                    • 47
                    • FLORIDA
                    #29
                    PLG1: 10 ohms both sides
                    PLZ2: 8.7 ohms both sides
                    PL1002 165 ohms both sides
                    the rest of the coils are 0L. both sides. no charger plug. no power on.
                    With charger, no power on:
                    PL102: 3.0v both sides
                    PL303: 0v both sides
                    PL302: 3.6 mV both sides
                    PLZ2: 0V both sides
                    PLG1: 0V both sides
                    PL1002: 0V both sides
                    PLM2: 0V both sides
                    When I press power button (what i can see on multimeter)
                    PL102: 3v both sides
                    PL303: 3.6v for a split of second
                    PL302: 5.19v for a split of second
                    PLZ2: around 100mV
                    PLG1: around 100mV
                    PL1002: 1.75v - 1.007 for a split of sec
                    PLM2: .381v for a split of second
                    • iplaypty
                      • Aug 2017
                      • 47
                      • FLORIDA
                      #30
                      Thank you very much tibd and ktmmotocross.
                      I was able to fix it.
                      I injected some amps on JPHW7 and found the bad cap next to UR1.
                      I removed it and now it turns on and show image on screen.
                      Is it important to place another cap there as replacement?
                      Thanks!
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3610
                        • slovakia
                        #31
                        Thanks!
                        Never start without some component.
                        Yes replace it.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3610
                          • slovakia
                          #32
                          looks like it is on pin 9 of UR1, which is +AVDD12 and thre are two capacitors CR3 and CR4
                          • tibd
                            • Oct 2014
                            • 189
                            • Sweden
                            #33
                            Very good, and yes you need to replace that cap. Originally rated for 6.3v in parallel with a 16v cap (CR4). I would change with at least 10v-16 rating. As of capacitance same as original 4.7uf.
                            • iplaypty
                              • Aug 2017
                              • 47
                              • FLORIDA
                              #34
                              ok, Thank you!
                              • iplaypty
                                • Aug 2017
                                • 47
                                • FLORIDA
                                #35
                                ok, thank you!
                                • mainah njoroge
                                  • Aug 2017
                                  • 36
                                  • kenya
                                  #36
                                  I have the same problen did u get any solution
                                  • mainah njoroge
                                    • Aug 2017
                                    • 36
                                    • kenya
                                    #37
                                    I took some pictures with my phone.
                                    The owner of the laptop told me that he was using the computer, then it suddenly turned off.
                                    Did u manage the laptop because i have the same problem
                                    • Andreasbest
                                      Dell Latitude 7410 dead and amber light as long power button is pressed.
                                      by Andreasbest
                                      Hello.
                                      I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                                      Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                                      Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                                      Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                                      12-21-2024, 02:02 PM
                                    • zwect
                                      Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                      by zwect
                                      I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                      Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                      Here is the original BIOS dump from the 25R256JVEN chip.
                                      09-11-2024, 05:54 PM
                                      Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                      by sam_sam_sam
                                      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                      I also have back when Light of America had these light bulbs available for yard lights
                                      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                      While the Lithonia lighting fixture has all most certain bulb failure
                                      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                      I have only had this light fixture for not more than a year if it...
                                      07-02-2023, 03:45 PM
                                      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 03:40 AM
                                      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 09:10 PM
