Z585 0x000000A5 setup error win7 win8
  • crocush20
    • Feb 2016
    • 17
    • qweqweq
    Z585 0x000000A5 setup error win7 win8 help me
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Z585 0x000000A5 setup error win7 win8
    please explain more about the error. A photo of the screen would help.
    when does it happen?
    where does it happen?
    what are other symptoms?
    • petehall347
      • Jan 2015
      • 4439
      https://www.google.co.uk/url?sa=t&rc...OZ_V5AVkf7elH_
      • crocush20
        • Feb 2016
        • 17
        • qweqweq
        • RJARRRPCGP
          • Jul 2004
          • 6304
          OK, that's a genuine BSOD... Now when does that code occur? Is it when using hibernation? If not, then the Windows kernel probably falsely thinks the BIOS is pre-2000-spec. or pre-1998-spec.
          Microsoft software products, at least one of them in the past, has been known to have integer-overflow conditions. That can cause a program or the system to report the hard drive being smaller than the actual size, such as "64 GB" on an 80 GB hard drive, or the system to report that the BIOS is Windows 95-era, LOL.
          https://en.wikipedia.org/wiki/Integer_overflow#Examples
          If it's not an integer overflow, which is less likely with 64-bits, then it looks like some absurd checker that's part of the kernel.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Its all about bios settings.
            • crocush20
              • Feb 2016
              • 17
              • qweqweq
              Bios help '
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • sushilachuthan
                APC UPS error P13
                by sushilachuthan
                one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                We replaced the SCR with new device,, but the device is not power on as expected.
                Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                09-26-2025, 09:00 AM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
              • Curtissimo
                HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                by Curtissimo
                Hi everyone.
                I have a HP Elitebook 850 G8.
                Serial: 5CG2324XM0
                ProdID 6L8D5EC#ABA
                It has a Winbond W25Q256JVEN Chip.
                I need to remove BIOS Password.
                I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                Attached my dump.
                I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                What I did:...
                08-26-2025, 04:42 AM
              • Maalobs
                Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                by Maalobs
                I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                The relevant service manual for the chassis is available here.
                The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                When I short the SDM to ground I get the layer-2 error code 53.
                The inside of the TV has no damaged components and no swollen capacitors.
                In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                04-02-2019, 01:15 PM
