need suggestion for buying cheap microscope
  • String2016
    • Nov 2015
    • 2235
    • philippines
    hi friends i need suggestions of buying cheap microscope below is the link.I just want to ask if this one is ok?
    https://www.aliexpress.com/item/1-60...999.263.eEHk7i
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: need suggestion for buying cheap microscope
    This video has a review of a similar item looks the same but different maker
    https://www.youtube.com/watch?v=bpbCyxlvlNc
    same microscope in use in this video looks a decent picture on the lcd at around 32 mins
    https://www.youtube.com/watch?v=zJpIM-dOVrk
    this is the one i may go for myself as i dont need to record anything
    http://www.ebay.co.uk/itm/AmScope-10...19.m1438.l2649
    • diif
      • Feb 2014
      • 6978
      • England
      I'm pretty sure someone asked the same thing a couple of days ago.
      It's better than no microscope but a real stereo microscope IMO far far better.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        that is right.
        I use a cheap microscope and my eyes are getting faulty.
        I hope I get rich soon to buy a good microscope such as AmScope.
        • String2016
          • Nov 2015
          • 2235
          • philippines
          thanks for the response friends do you have a link for a cheap microscope for below 100$?
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            I suggest you optical microscope
            • bohaboha
              ADVICE FOR BUYING A DIGITAL MICROSCOPE
              by bohaboha
              Hi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
              the one i choose is the D full Set
              maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for...
              02-24-2025, 07:13 PM
            • chegueva
              My Andonstar ADSM201 Microscope Review
              by chegueva
              Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
              About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
              So i had a choice between a binocular & camera , i wanted...
              08-14-2020, 11:08 AM
            • lcdcaps1
              INSKAM Microscope USB port issue
              by lcdcaps1
              Hi
              All
              Does anyone have a INSKAM 7 inch LCD digital microscope
              I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
              The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
              I have tried different cables and different USB power adapters
              I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another...
              04-18-2025, 04:16 AM
            • ledbylight
              M1 A2337 Macbook - No Display, likely due to logic board
              by ledbylight
              Hi all!
              This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
              I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
              11-04-2024, 06:36 PM
            • caspian
              Weak Vision due to Eye Strain when using Microscope
              by caspian
              Dear Forum Members,
              Microscope is required for micro-soldering and for measuring tiny components on a mainboard. I have to use microscope because my eyes are not that strong to see tiny IC pins.
              My microscope has light to improve vision. I have attached a photo of my microscope.
              Looking through a microscope gives us eye strain. After using microscope for 5 to 10 minues, my eyes get a bit weak in recognizing close objects. that means close objects look a bit blur. Then, I have to wait for 5 to 10 hours til my eyes get back to normal.
              1. Do you experience...
              08-14-2019, 02:28 AM
