cfl screen inverter 6pin to 7pin
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    hi everyone i need help on this the ccfl screen inverter in broken on toshiba l505 laptop the inverter has 6pin and i cannot find the same replacement for this i have here available only the same size and coil but the problem is the available has 7pin it is possisble to use this to convert the 7pin to 6pin?please i need help on this please i have attached the image
  • mielta
    • Apr 2015
    • 368
    Re: cfl screen inverter 6pin to 7pin
    Hi
    You can try it
    By the Inverter there is one pin power (Vcc) i think 5v or 19v
    another one is enable (Backlight on/off) i think 3.3v
    an another one is ajustable voltage for brightness
    and the last one is ground
    2 Pins are not connected (nc)
    • Romulo
      • Nov 2016
      • 484
      • Philippines
      thanks for the response mielta can you show me please how to convert with this the broken is 6pin and the available replacement is 7pin
      • mielta
        • Apr 2015
        • 368
        were the fuse is is VCC and ground you can also messure
        you must check the chip on the inverter with 7pin for an datasheet
        to find where is enable and Dim
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          i already checked the 7 pin inverter pin 1 and 2 vcc has 19v standby voltage 6 and 7 are ground when i turn on the laptop pin 3 and pin 4 have 3.3v and pin 5 have 1.2v
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Try by shorting pin 4 & 5 of inverter and see if voltage remains 3v. Very likely you will get backlit on.
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              thanks mcplslg123 but the problem is 6pin inverter the ground is pin 5 and the 7pin inverter the ground is in pin6 and pin7 i need to replace the 6pin inverter to 7pin how can possibly do this please
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                19v to vcc pin
                gnd to gnd
                3v in pin 3 or 4
                3v/1.7v on pin 4 or 5.
                Technically thats the requirement for backlit to be on. You will need to apply 3v on those pins by permutation and combination to find out.
                eg, vcc and gnd connected, then apply 3v on say pin3 and try putting 3/1.7v on pin 4 or 5. see which works
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
