Asus X550LC black screen for a couple of minutes then boots
  • piernov
    • Jan 2016
    • 4435
    • France
    Asus R510L laptop with a X550LC rev 2.0 motherboard in it.
    It takes a couple of minute for the screen to turn on, each time you shutdown/reboot the computer. No issue waking up from sleep.
    While it is showing a black screen, the power led is on, the WiFi led and HDD led are flickering every second or two and the HDD makes a ticking noise. (HDD is not the issue, I tried with another one)
    Once it has booted, everything apparently works perfectly fine.
    Suggestions?
  • kiraro
    • Jan 2016
    • 177
    • North NY
    Re: Asus X550LC black screen for a couple of minutes then boots
    Try with this clearme bios for x550lc rev2.0 ,this will fix your slow boot .
    • piernov
      • Jan 2016
      • 4435
      • France
      Thanks, I'll try in the next couple of weeks, I don't have the laptop right now.
      • deepak47
        Asus GA503RM ON BUT AFTER LOGO AND SOUNG SCREEN GOES OFF AND WINDOWS BOOTS PROPERLY
        by deepak47
        Hello Everyone,
        I have this Asus DANJPMB2AB1 REV:B
        laptop getting on but after logo and sound screen gets off but the windows does boot properly, moreover it stays on in bios menu.
        ​​​help me please...
        10-19-2024, 10:46 PM
      • abajor
        A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
        by abajor
        Having this very weird issue.
        The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
        I swapped with a working screen from an A2141 waiting for parts.
        The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
        The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
        04-27-2024, 01:37 PM
      • FallenOne008
        Asus G712L No Screen Backlight
        by FallenOne008
        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
        03-31-2025, 08:27 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • krige
        asus g750js ms1130c (203) turns on nothing on the screen
        by krige
        hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
        03-22-2024, 04:59 AM
