I have asus n61jv and hp pavilion g6 all intel processors, the problem I have with them is that, computer works perfectly but there is no image or text on screen. I have checked 3.3v to Lcd and its ok, I get a grey display. can anyone point to me to some things I should check. I have already changed display cable and screen but no results.
Troubleshooting No image or text on screen
Re: Troubleshooting No image or text on screen
First step always , is to try an external monitor , and the second is to acquire the original display cable , as we see many fake or chinese crap forgery .
Third step is to check visually around the display cable inlet on board , searching for a burnt transistor or resistance (in case you don't have the schematics ) , or take the necessary measurements if you have them .
Some Laptops also do have specific screen requirements like HD , WXGA , Etc , etc , and standard replacement screens simply won't fit , so better acquire the original . -
Some Laptops also do have specific screen requirements like HD , WXGA , Etc , etc , and standard replacement screens simply won't fit , so better acquire the original .Comment
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by speedtime07hi everyone ,
There is an image on the external computer screen ,
flexi cable test ok - screen test ok -
What alternative should I look for?
thank you for your support​ -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
