toshiba c55 -c1587 backlight. not working
  • crowntoy99
    • Oct 2012
    • 264
    • india
    toshiba c55 -c1587
    DA0BLBMB6F0 rev e
    backlight. not working led
    extanel monitor working ples help me
  • mielta
    • Apr 2015
    • 368
    Re: toshiba c55 -c1587 backlight. not working
    Hi
    have you schematic ?
    • crowntoy99
      • Oct 2012
      • 264
      • india
      Originally posted by mielta
      Hi
      no bro
      https://www.badcaps.net/forum/showth...&highlight=L50
      i replace bios just 1 minute working after the screen white then one gen saim black screen
      • crowntoy99
        • Oct 2012
        • 264
        • india
        toshiba c55 -c1587
        pskwtv-00h00ear
        DA0BLQMB6E0 REV :E
        MODEL BLQ
        CORE I7 WITH NVIDIA
        NEED BIOS PLES
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          try this
          Mod edit: bios moved to "Bios requests ONLY!" section https://www.badcaps.net/forum/showthread.php?p=1171416
          Im Back... sort of...
          • crowntoy99
            • Oct 2012
            • 264
            • india
            Originally posted by ala_borbe
            try this
            ITS WORKING BOUT SAME THANK YOU BRO I return TO customer ...
            • Boxino
              • Feb 2022
              • 20
              • Zambia
              i have a toshiba c55 but when i instal the operating system it starts to loading but after a while it get stuck on the logo what could the problem.
              • mon2
                • Dec 2019
                • 14201
                Try again but boot using SAFE MODE.
                Does it boot ok now?
                Very likely that you have installed a bad device driver that will be forced to stop loading when in SAFE MODE.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Many toshiba models have NEC Tokin caps. Does your model also has it??
                  • stoian_93
                    Finlux LED backlight not working
                    by stoian_93
                    Hello guys!
                    My Finlux TV backlight stopped working. I disassembled the TV, saw I don't have the tools to replace the backlight and assembled it again without replacing anything. So then the backlight started working again.
                    A day after it is also not working.
                    I decided now to remove the back cover and get the output voltage to the backlight. I placed the TV facedown and connected to the mains, so - nothing. I disconected, removed the cover and connected again to the mains and then the backlight lighted again. So strange.
                    Output voltage when light is 66V.
                    Board: VESTEL...
                    08-19-2023, 12:32 AM
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                    09-06-2024, 05:27 AM
                  • knoxrebel
                    TCL 65s425 sound/video working, no backlight
                    by knoxrebel
                    Tv shows no issues other than no backlight. Picture was visible with flashlight and menu navigation possible with audible responses.
                    Polyester film Capacitor c620 27nf (on power supply board had visible brown discoloration, but is not shorted. Replaced with suitable spare and now working properly. (Apparently this is a known issue with this series.)
                    Backlights tested independently with tester and registered ~140vs on each.
                    40-L171w4-pwa1g
                    Mmkp82 1kv 273 J...
                    01-12-2025, 03:33 PM
                  • PITERPENY
                    MacBook Air A1932 Keyboard backlight not working
                    by PITERPENY
                    After updating the system to Sonoma, the keyboard backlight does not turn on! Preinstallation through recovery did not change the situation. Resetting smc and pram did not help! restore via dfu is also zero! I put the board in another Mac and it turns on the light! I put a board from another Mac into this one and the backlight works too! Only the original board does not turn on the backlight! Can anyone please advise, I beg you!
                    03-13-2024, 07:01 PM
