Convert K55VD REV 3.0 DIS->UMA
  • kiraro
    • Jan 2016
    • 177
    • North NY
    hi my friends ,
    today i share how to convert k55vd dis to uma REV 3.0 (and also my mistake to learn from it ).
    this method work 100% tested ,but my mistake it was ,i forget to install a heat sink for the chip, i discover that later ,first it was ok, after few time the spin work on full speed and i discover that the chip was hot , (in my case i broke it but we learn from our mistakes ), then if you wanna convert to uma you should install an heat sink for a chip like on other old asus model ,see pictures attached.(i doubt in bios problem or processor problem but after i broke it i discover that ,hope that may help some one, BUT YOU SHOULD INSTALL A HEAT SINK).
    tested and worked fine and successful conversion .
    hope that help someone .
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Convert K55VD REV 3.0 DIS->UMA
    thanks for sharing.
    does the process involve only removing those mentioned components?
    is reprogramming EC or main BIOS required too?
    • kiraro
      • Jan 2016
      • 177
      • North NY
      You don't need to reprogram ec or bios,just remove those components,and it will display directly .
      • String2016
        • Nov 2015
        • 2238
        • philippines
        what do you mean installed heatsink you mean installed a fan?thanks for the sharing
        • kiraro
          • Jan 2016
          • 177
          • North NY
          Sorry for my bad English ,I mean install a little piece of cooling system like in the second picture is for Asus model also you can for example do the same just take it from old model and installed in k55vd ,the place to fix it already exist in motherboard see red circle in the second picture. Hope that help you ,my mistake it was I forget to install this little piece and fix it .
          • sourcebf
            • Jul 2016
            • 433
            • N/A
            thanks for sharing
            • String2016
              • Nov 2015
              • 2238
              • philippines
              Ok thanks for sharing
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                It's not possible remove the bga to solve this issue ?
                I don't see the boardview but probably it's possible to disable all gpu voltages
                removing some resistors it's not the best thing having a damaged component onboard
                • kiraro
                  • Jan 2016
                  • 177
                  • North NY
                  You have right,but for those who don't have conditions or materiel to change the GPU ,this still a solution also.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Thanks for sharing friend
                    • chocoyito
                      • Sep 2016
                      • 16
                      • peru
                      thanks bro!
                      • Qalib
                        • Jun 2016
                        • 9
                        • Mingechaur
                        Thank you my brother.
                        • lesterbrazal
                          • Aug 2011
                          • 38
                          thanks
                          • fyaagoub
                            • Dec 2016
                            • 269
                            • maroc
                            thanks for sharing
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3627
                              • slovakia
                              1. why remowing when u can damage board when removing and after remove u have exposed pads that u must solve
                              2. when u disable gpu voltages u must correct non working PWRGOOD signals
                              3. it is the best as wrote in 1.
                              • Leutzu
                                • Jul 2020
                                • 3
                                • Romania
                                A friend of mine has an K55VD but REV 3.1
                                He told me that one day it stopped working, previously he had some times when the laptop refused to boot, but after long pressing power button and powered it again it worked.
                                Could it be the graphic chip or a failed BIOS? How can I tell?
                                • asliyucegsm
                                  • Jun 2011
                                  • 350
                                  • Turkiye
                                  My friends, can this asus k55vd rev.3.1 be made into uma?
                                  • Sus256
                                    HISENSE 65E7KQ PRO - no boot
                                    by Sus256
                                    Hi all!
                                    HISENSE 65E7KQ PRO
                                    RSAG7.820.13512 - chassis
                                    MT9618BAATAB - cpu
                                    RSAG7.820.12059 - power
                                    HD650Y3U77 - panel
                                    KLM8G1GETF - emmc
                                    The TV does not turn on, the standby indicator is on. All voltages are present.
                                    Emms is dead. Not readable, not detected.
                                    Replaced emmc.
                                    But with another dump there is no launch
                                    Terminal log
                                    UART
                                    AC_ON
                                    RPMB key is not yet programmed
                                    HASH1_VERSION=0x00000000 64bit
                                    E-B
                                    FDE enabled
                                    layout pattern onebin by SAR7,0...
                                    06-01-2025, 02:11 AM
                                    HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                    09-06-2024, 11:17 AM
                                  • japlytic
                                    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                    by japlytic
                                    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                    Tried (only with keyboard/mouse connected):
                                    • BIOS + database update
                                    • Using latest Windows 11 image built with official image creation tool
                                    • Previous setup version for Windows 11 installer
                                    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                    06-19-2025, 04:59 PM
                                  • 24gsm
                                    MacBook Pro A1708 install macos fail
                                    by 24gsm
                                    hi to all
                                    i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                                    after enter to recovery and format hdd 1to .
                                    after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                                    can help please
                                    Serial Number: FVFXP0U0HV2J
                                    Config Code: HV2J
                                    Find My Mac: OFF
                                    04-16-2025, 03:57 AM
                                  • duwane
                                    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                    by duwane
                                    Hi All.
                                    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                    The issue:
                                    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                    10-26-2022, 07:02 AM
