UX31A +VGFX_CORE missing
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Asus ux31a, cpu cold bios reprogrammed:
    5v and 3v ok but
    power adaptor led is orange without battery
    +VGFX_CORE 0 volt
    on PU8000 RT8168B:
    VRM_PWRGD 0v <------???? come from ITE --> SUS_PWRGD 3V
    P_GFX_TONSET_10 19v
    P_GFX_BST_30 5v
    P_VCORE_VDDP_30 5v
    P_VCORE_BST_30 5v
    P_VCORE_TONSET_10 19v
    P_VCORE_TMPMAX_10 2v
    P_VCORE_OCSET_10 2v
    P_GFX_OCSET_10 2v
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: UX31A +VGFX_CORE missing
    After a test with power on sequence schemas, I found :
    PWR_SW# -> H -> L after push (STEP 8)
    EC -> PCH:
    PM_PWRBTN# -> L (STEP 9)
    PCH -> PM_SUSB# -> H -> should be active low (STEP 11)
    PCH -> PM_SUSC# -> L -> is active (STEP 12)
    Seems to be an issue with pch because PM_SUSB# is Hight
    it's true?
    • ugamazing
      820-02020 PPBUS_AON missing
      by ugamazing
      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
      02-05-2025, 04:21 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
    • gurj1979
      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
      by gurj1979
      Hey guys.
      Need help with this one.
      Fan not spinning due to missing PWN Fan signal.
      Also 5 seconds from powering up it freezes, unless in BIOS.
      But as soon as Windows starts to load, it will freeze.
      CPU is COLD / Room temp when it freezes.
      I've replaced the CPU, same problem.
      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
      Replaced fan - same problem.
      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
      08-19-2024, 05:22 PM
    • salopian
      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
      by salopian
      Hello. I would need some advice please.
      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
      I have already replaced the logic board with another...
      02-27-2021, 07:30 AM
    • ein_individuum
      Missing Capacitator Intel I9-12900KF CPU
      by ein_individuum
      I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
      I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
      Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
      08-06-2025, 01:36 AM
