HP G62 Blinking power button
  • John_F_L
    • Mar 2017
    • 72
    • Greece
    I have 3 HP G62 (mb: 615382-001 and 610160-001) all with the same problem.
    The power button is blinking, I have the 3,3V and 5V if I press and keep the power button, but the 19V rail is not stable. It is going from 19V falling to 8-10 and again 19 and so on. I already tried to change the MAX8731AETI and the same thing happens.
    Also if I remove the PJ1 or the PJ15, the 19V is stable, no up and down.
    I haven't change the PU850 - PU11 (SN0608098) because I don't have a spare one (I don't believe that my problem is there because I have the 3,3V and 5V).
    Also I have checked all the coils for short to ground, none of them is shorted.
    Battery is dead, so I don't know if the laptop starts only with battery.
    Any other thought would be great.
    Edit:
    after searching a little bit, I cleaned pj542 and until there I have stable 19V and 3.3V on PL11. I cannot find any short on the line after the PJ542.
    Also another thing I saw is that on pin 11 where is supposed to be +V3.3S i measure 1.8V. I tried to find out if there is a problem with the +V3.3s but no luck.
    Thank you.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: HP G62 Blinking power button
    if u hve non stable VIN after start u must have short in some powerswitched rail.
    post schematic
    • John_F_L
      • Mar 2017
      • 72
      • Greece
      i'm posting both the schematics of the two motherboards.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        check for short on all PJ jumps
        • John_F_L
          • Mar 2017
          • 72
          • Greece
          i checked for short but none of them had one.
          Today I got another one that had a temp problem. I connected it to my power supply and saw the same thing. I said no way, so I got the customers psu and worked fine.
          Then I tested the customers psu with those laptops I had the problem, the 2 worked fine, the third one ( 615382-001 ) I press the button but nothing happens. No fan spin, no light, nothing. The 19V are stabilized.
          I'm thinking reflowing the chipset for start and if it works, I'll reball.
          • John_F_L
            • Mar 2017
            • 72
            • Greece
            I tried today these:
            1. Change the bios chip with a new one.
            2. Reflowed the Chipset to be sure before reballing.
            3. Change CPU and Ram from a working one.
            After all the changes, nothing happened again. I press the power button and it's not working. The only thing I have after the power button is the 5V rail for 5-6 seconds.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              u have power timing in schematic so go after that
              • John_F_L
                • Mar 2017
                • 72
                • Greece
                Hello again, I couldn't find what was the problem, I just gave it to the customer unrepaired.
                Thank you for your answers.
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  try to convert to uma, it can be shorted vga chip or balls under vga
                  you have a thread here on forum
                  Im Back... sort of...
