Lenovo Yoga2 13- No display and light only on keyboard
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 345
    • India
    Re: Lenovo Yoga2 13- No display and light only on keyboard
    Thanks i will check , and update you soon .
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 345
      • India
      Just an update now what went wrong while testing board ON & OFF, fan not spinning ,Showing short at PL802 +1.05V. opened jumper PJ801 ,L1,2,3,4,5,
      couldn't find exact component .nothing heating
      now no power at PL704 ,PL502
      • mhf0000
        • Apr 2021
        • 10
        • lebanon
        Originally posted by Pferd5
        It's 5 seconds LED on and I have a board with the same issue. If somebody has an idea what to to.. I would me more than happy.
        I checked 19v, 3.3v, 1,35v, 5v... all on.. CPU 1.68v is also coming up.
        It's consuming 0.06 till 0.010 Amps in IDLE. And while power on (till power off in 3-5 seconds) 0.280 amps.
        hi i have the same problem yoga 2 pro turn on then off no signal the problem was the cpu after reballing the cpu it works again normally if cant make a reball process just heat it for 2 min on 250 degrees it should fix your prblem
        • webwicht
          • Oct 2021
          • 8
          When reading out the bios rom chip (WINBOND) from my Lenovo yoga 2 13 with a faulty flasher I damaged the bios rom chip and possibly other devices. (The CH341 flasher sent 5V instead ov 3.3 V to the lines)
          I had a backup of this rom on the hd and flashed it into a new rom chip.
          Now when powering on: the keyboard light is on and the fan runs for a couple of seconds but the screen stays black. (This is better than with the damaged bios chip where the fan did not run and the laptop power cycled in an endless loop)
          Any hints what I could try before buying a new motherboard?
          Thank you in advance.
          • webwicht
            • Oct 2021
            • 8
            I have 2 ideas what to do:
            1. The Bios and EC version was 1.15 whereas the Bios-backup was 1.17
            1V$96CN31WW(V1.17) since I downgraded it in the wrong hope some wifi cards would be accepted.
            Must EC and Bios match? If so I need to prepare a downgraded Bios or upgrade the EC.
            2. Since the faulty flasher sent 5V it might be that the ITE chip burnt. If so I could replace it.
            What is the expert's suggestion?
            • webwicht
              • Oct 2021
              • 8
              I checked the signal lines of the 25Q64FSVSIG chip where I flashed the bios-Binary to and actually a short data transfer occurs. So I would assume ITE is not dead yet.
              • baddjavo
                • Jun 2018
                • 87
                • Serbia
                #27
                I have similar problem yoga 2 13 , power led on for few second then off, repeating.
                Notices 1.7V on core voltage coil PL704, is this normal voltage ?
                • baddjavo
                  • Jun 2018
                  • 87
                  • Serbia
                  #28
                  I checked lost of signals, its not thermal alert, core voltage is 1.73 volts.
                  Problem solved using virgin bios Ala_borbe provided on this forum.
                  • mon2
                    • Dec 2019
                    • 14120
                    Well done. Thanks for your update!
                    • playit
                      ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                      by playit
                      my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                      my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                      few years back ps2 mouse stopped working, but ps2...
                      12-23-2024, 06:05 AM
                    • FZG
                      Lenovo Yoga 6 (13ALC6) keyboard not recognized
                      by FZG
                      Lenovo Yoga 6 13ALC6
                      Model: 82ND
                      Board: LA-K211P
                      Schematic: https://www.badcaps.net/forum/docume...ic#post3482405
                      Hi guys!
                      I recently bought a Lenovo convertible Laptop (Yoga 6 13ALC6) in faulty condition. It originally had a corrupted BIOS but I was able to resolve this by flashing a clean bin. Now the laptop works fine except for one thing, the keyboard. It does not work in Windows but it works in BIOS setup. The keyboard itself is probably not at fault, every single key...
                      06-28-2025, 11:23 AM
                    • MrDadosz
                      Lenovo Legion 15IMH05 keyboard problem
                      by MrDadosz
                      Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                      When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                      In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                      Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                      I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                      08-15-2024, 05:07 AM
                      HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                      09-06-2024, 06:21 AM
                      HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
