Lenovo Yoga2 13- No display and light only on keyboard
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    i need request for bios clean for this.
    problem: No display and light only on keyboard
    Lenovo Yoga 2 13
    Mobo: LA-A921P
    5B20G19198
    Thank's
  • Attif
    Attif
    • Dec 2016
    • 49
    • pakistan
    Re: Lenovo Yoga2 13- No display and light only on keyboard
    keyboard on light but screen have no display ???
    1.u check the screen cable first clean and fix again.
    2. check the voltage on screen coming or not 3.3v and 19v
    • kjchatman
      • Dec 2012
      • 200
      • united states
      i have this same board and it doesn't stay on. i hit the power button and the keyboard lights and the fan beings to spin. after three seconds it will shut off. sometimes it will cycle and do the same thing twice or three times. i've also noticed that if i plug in an optical mouse that the red light is on even though i haven't cut the machine on yet. the cpu will stay warm even the machine isn't cut on
      • Pferd5
        • Mar 2018
        • 68
        It's 5 seconds LED on and I have a board with the same issue. If somebody has an idea what to to.. I would me more than happy.
        I checked 19v, 3.3v, 1,35v, 5v... all on.. CPU 1.68v is also coming up.
        It's consuming 0.06 till 0.010 Amps in IDLE. And while power on (till power off in 3-5 seconds) 0.280 amps.
        • Pferd5
          • Mar 2018
          • 68
          i checked all power raills. all are up and running. also replaced the bios (also chip) and tested 3 versions from different sources.
          I also soldered an LED on the bios on PIN 4 and 5... to visualize communication but it's only blinking once and than it's done... on an X1 there where several blinking.
          +3VS
          +3VALW
          +1.5VS
          +1.05VS_VTT
          +CPU_CORE
          +0.675VS
          are present and get shutdown after a 5 seconds.
          seems like the bios won't get read.
          If i delete the bios or remove the chip it's NOT powering off. it stays at 0.260 amps.
            • 20855
            Try this bios and EC ,extracted from lenovo bios, dmi added. Check how hot the KBC gets during boot up if this bios doesn`t work .
            MOD EDIT: bios moved - https://www.badcaps.net/forum/showthread.php?t=100248
            • Pferd5
              • Mar 2018
              • 68
              Many thanks... Unfortunatly I don't have an EC Programmer (yet?)
              Tried the Bios alone, no change.
              I guess we both guess it has to do with the EC Flash/Programm.
              No heart at all at the EC. Tested with thin layer of alkohol.
              (Would you recommend the: Vertyanov programmer?)
              • Pferd5
                • Mar 2018
                • 68
                ne heat (not heart)
                  • 20855
                  Originally posted by Pferd5
                  ne heat (not heart)
                  Have you tested with the LVDS connected .
                  • Pferd5
                    • Mar 2018
                    • 68
                    display was connected.
                      • 20855
                      Test R127,R128,RP4,RP6 and R108 if they`re on the board.
                      • Pferd5
                        • Mar 2018
                        • 68
                        What did you mean with dmi added with your bios? Isn't dmi in any bios by default?
                        RP4 (15 ohm)
                        RP6 (0) [i gues it's the one next to SPI flash, there is a red dot on the number, so I can't really read it, but makes sense while looking into schematic)
                        R108 (15)
                        Unfortunatly I can't locate R127 R128. Don't know where AF1, Y6 are to find.
                        Maybe you can show me where both resistors are located by this (random) picture https://e.allegroimg.com/original/0c...268e238ddc630e
                          • 20855
                          "What did you mean with dmi added with your bios? Isn't dmi in any bios by default?"
                          Your serial number,UUID,MAC address are in your bios backup,its the DMI info.The bios from lenovo doesn`t include it,its copied over during the bios update.Because your flashing the bios with a programmer you need to add the dmi info,manually with a hex editor or with dmi tools, either from lenovo or whoever made the board,compal,bitland .
                          There`s no boardview available so finding r127,r128 is going to be.. very difficult. I don`t know what else to suggest .
                          • Pferd5
                            • Mar 2018
                            • 68
                            I ordered the ec programmer... I will put the board aside for a while.. maybe reprogramming the ec will help.
                            Can you guide/give link how you edited the provided bios? extracting / adding the dmi part and maybe other interessting stuff that would be usefull to know?!
                            thanks for your help anyway.
                            • Pferd5
                              • Mar 2018
                              • 68
                              btw. I think I was wrong about 1.35v rail. Sorry for the faulty hint.
                              I'm pretty sure it's shorted.
                              unfortunatly the ram is soldered.
                              I made a picture with the powerline
                              There are 2 bridges (underneath they look the same) I removed them and than the short on the power supply side is gone (green).
                              I attached 1.35v and 3A to the grounded side (marked in blue) it draws 0.6v with 3A. I also tried with 5A (think it was 1v) but nothing really gets warm. Something should get warm but I can't feel it by hand or by evaporating alcohol. 5w should be enough to get something warm, but I couldn't find anything warm, so maybe it's really a RAM chip which can dissipate the heat too good?!
                              And of course more than the 4 caps in the red rectangle are shorted. They are just examples.
                              Any recommendations?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I dont think they are shorted as depicted in your pic-since ram is onboard they are showing short.
                                • Pferd5
                                  • Mar 2018
                                  • 68
                                  I messured the ressitance on the caps again and they are 0 Ohm. I also messured on a T440s (4GB onboard) and one some caps I get something about 100 Ohms. As far As I understand the repair logices (so far) there is a short on 1.35v. I'm more than open to test any recommendations what to do next.
                                  • ravi_1617
                                    YY Solutions
                                    • Jan 2012
                                    • 345
                                    • India
                                    Hi
                                    its same problem ,few times ON & OFF repeat ,than stays OFF.
                                    sometimes stays ON, CPU heats up and fan don't starts cpu heats up more and more, So i force turn OFF.
                                    any solutions
                                    • ravi_1617
                                      YY Solutions
                                      • Jan 2012
                                      • 345
                                      • India
                                      When laptop came USB 3 was broken pins were short.
                                      • Sametbey
                                        • Jan 2021
                                        • 229
                                        • Turkey
                                        I think there is a caps failure in the 1.35v line. If ram chips had short circuits, they would have been warmed up. It should be very troublesome to control ram chips by removing them one by one. It should also find a guide to cancel ram chips.
                                        I'm not happy to be so strong. because it's not humanly
                                        • playit
                                          ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                          by playit
                                          my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                          my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                          few years back ps2 mouse stopped working, but ps2...
                                          12-23-2024, 06:05 AM
                                        • FZG
                                          Lenovo Yoga 6 (13ALC6) keyboard not recognized
                                          by FZG
                                          Lenovo Yoga 6 13ALC6
                                          Model: 82ND
                                          Board: LA-K211P
                                          Schematic: https://www.badcaps.net/forum/docume...ic#post3482405
                                          Hi guys!
                                          I recently bought a Lenovo convertible Laptop (Yoga 6 13ALC6) in faulty condition. It originally had a corrupted BIOS but I was able to resolve this by flashing a clean bin. Now the laptop works fine except for one thing, the keyboard. It does not work in Windows but it works in BIOS setup. The keyboard itself is probably not at fault, every single key...
                                          06-28-2025, 11:23 AM
                                        • MrDadosz
                                          Lenovo Legion 15IMH05 keyboard problem
                                          by MrDadosz
                                          Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                                          When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                                          In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                                          Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                                          I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                                          08-15-2024, 05:07 AM
                                          HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                                          09-06-2024, 06:21 AM
                                          HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
