MacBook A1278 / MB 820-3115 B / Pad missing
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello ,
    I have received this Macbook and pad of fan motor control is missing , and pad of pin1 Q5660 is missing too...
    The owner is saying that is complicated because the noise that the fan is doing is boring ,
    What can i do in this situation ? How can i put the fan working good with the motor control ?
  • techman1025
    • Jun 2014
    • 497
    Re: MacBook A1278 / MB 820-3115 B / Pad missing
    Hi Real easy just open boardview file locate where that pad run's to run a wire done.
    Techman1025
    • dmartins
      David M
      • Apr 2014
      • 197
      • Lisbon
      The pad run to pin1 of Q5660 but this pad is missing too
      • Adogabriel100
        Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
        by Adogabriel100
        Hey! This is a A1278 macbook 2011.
        Problem: Not turning on / No green light
        Im using by3200s charger.
        Voltajes:
        PPBUS_G3H = 12.26v
        SMC_RESET_L = 3.3v
        PP3V42_G3H = 3.42v
        U7000 =
        Pin 1 CHGR_AGATE = 0v
        Pin 2 CHRG_DCIN = 19v
        Pin 3 CHRG_ACIN = 4.6v
        Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
        Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
        Pin 12 PP3V42_G3H = 3.42v
        Pin 13 CHRG_RST_L = 3.3V
        Pin 14 SMC_BC_ACOK = 0.8V
        Pin 19 PP5V1_CHRG_VDD = 5.05V
        Pin 20 PP5V1_CHRG_VDDP = 5.03V...
        04-01-2024, 01:02 PM
      • Rezendes
        Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
        by Rezendes
        Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
        I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
        The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
        05-10-2024, 02:18 PM
      • pcbmaniac
        MacBook A1278 (3115) No PPBUS_G3H Issue
        by pcbmaniac
        Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
        I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
        1. U7000 Measurements:
          • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
        2. Resistors:
          • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
        Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
        • If I also decide to replace the SMC, do I need to order it pre-programmed,
        12-02-2024, 04:12 PM
      • envym
        MacBook Pro 2018 with Activation Lock
        by envym
        Hi everyone!
        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
        06-27-2025, 08:54 AM
        Apple MacBook A1278 051-7918 820-2327 Schematic
        M97A MLB Rev C...
        11-01-2024, 06:53 AM
