help needed with BQ24737 ACOK
  • rookieme
    • Oct 2014
    • 396
    • Greece
    I have a dell that fails to charge batteries.
    The charger circuit is BQ24737 [the schematic shows different part, also I could only find a datasheet of BQ24735].
    I could narrow my search at the fact that ACOK is 0V [the pull up resistor PR4434 is ok and gets the 3D3V_AUX_S5].
    ACDET is 2,44V
    VCC is 19,55V
    SRN is 2,6V [without battery]
    datasheet says:
    voltage on VCC is 275 mV above voltage on SRN pin, indicating a valid adapter is present to start charge
    but this makes no sense as VCC is much above the battery voltage.
    what am I missing?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3561
    • slovakia
    Re: help needed with BQ24737 ACOK
    It is not 735
    For me it looks like 707
    https://cdn.badcaps-static.com/pdfs/...107dc7e515.pdf
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      ktmmotocross was right, ACOK should be LOW, because the signal should not trigger PWR_CHG_ACOK to pulling down to GND.
      • smali
        • Sep 2014
        • 287
        • Pakistan
        you should check the resistor PR4416? is it OK?
        • rookieme
          • Oct 2014
          • 396
          • Greece
          the PU4404 is marked clear with BQ737
          PR4416 has been measured ok - I have never seen one fail as it's a load resistor
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Your attached schematic shows on page 98 & 97 are BQ24717 and BQ24715. But both are same. In my experience I Replaced for BQ24736 by BQ24725. It is working on a HP Probook 450 G2 Laptop.
            • rookieme
              • Oct 2014
              • 396
              • Greece
              also noticed at page 43 close to down right corner mentions BQ24707
              so what is the correct charger ic for this?
              am I having charging issue from that ic?
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                BQ24707 also same Data on all pin so no problem if you want to replace it you can use 707, 717, 715, 725, 735, 736, 737 also same pin arrangement.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3561
                  • slovakia
                  r u kidding right?
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    AFAIK:
                    BQ707, BQ727 need ACOK LOW
                    BQ725, BQ735 need ACOK HIGH
                    Check datasheet again!
                    And a few different the pin out also I think New of the IC only for support Turbo Boost Mode.
                    • raajkumar
                      • Mar 2015
                      • 354
                      • Srilanka
                      Yes you are correct. I used the datasheet to check pinout for BQ735 to BQ725 it is working without any problem. Actually i didn't check for BQ707, 717, 715. I checked for 725, 735 only its using 1 to 4 cell batteries.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3561
                        • slovakia
                        707 and 735 cannot be interchanged.
                        • rookieme
                          • Oct 2014
                          • 396
                          • Greece
                          So in my case could somebody replaced 707 with 735 before?
                          The 707 seems the correct one?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3561
                            • slovakia
                            maybe u post wrong schematic
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              http://notebook1.ru/forma1/viewtopic...767636#p767636
                              https://drive.google.com/open?id=0Bz...WNGSmtxalJKY3M
                              • rookieme
                                • Oct 2014
                                • 396
                                • Greece
                                that picture confirms that the 737 is the correct one
                                • JLCurve
                                  • Feb 2017
                                  • 32
                                  Hi!
                                  Did you successfully replace the 24737 for a 24707 (available at DK)?
                                  I also have a board (NM-A032) that has a 24737 charger that does not seem to want to do anything. All voltages seem fine, including the 6V ldo output but it does not start charging.
                                  The board had a shorted capacitor on VIN ..
                                  Thanks,
                                  Joseph.
                                  • hrfam
                                    • Nov 2017
                                    • india
                                    hi ....test gate on p1 &p2 mosfet ...if have 19v acprn is missing //check acprn {acok} block under schematic page
                                    • Faijul Hasan
                                      • Jul 2019
                                      • 4
                                      • Bangladesh
                                      any one give me bq24736 datasheet
                                      • Sametbey
                                        • Jan 2021
                                        • 229
                                        • Turkey
                                        Especially for the Dell notebook, the adapter is important. original adapter (contains the thin pin adapter information of the adapter socket). Without the proper adapter, charging may not start. similar charging circuit. The 737 to 735 ACDRV differ.
                                        I'm not happy to be so strong. because it's not humanly
                                        • battery.12v
                                          BQ24737 No ACOK#
                                          by battery.12v
                                          Lenovo B50 LA-B091P ... BQ24737 ==> VCC 19V , ACDET 2.59V, SRN 2.2V, REGN 6V, ALL mosfets are OK and Power Rail not Shorted and ACOK wont Pull Low !!! So second Power mosfet will not be active ... is there another signal responsible of activating ACOK# in this situation ?? it must pull down to ground so the signal PACIN go HIGH
                                          01-20-2020, 06:16 AM
                                        • benjas11
                                          BQ24780S (acok missing)
                                          by benjas11
                                          Hello everyone, I need your help. I'm having issues with a Lenovo motherboard. When I plug in the charger, there's no current consumption. However, the laptop works if I bypass the charger IC by applying 20V directly to the main resistor. I checked the voltages at the charger IC and found that ACOK (AC OK signal) is missing, and ACDRV (AC Drive) isn't sending voltage to the gates. I've searched for shorts but found none. I replaced the charger IC three times, but ACOK remains around 0.24V–0.35V. The MOSFETs test fine. If anyone has encountered this issue, I'd appreciate your advice.​
                                          05-21-2025, 01:18 PM
                                        • bridges_4u
                                          DK10FG-6050A2491301-MB-A03 missing ACOK
                                          by bridges_4u
                                          Hi there,
                                          I have a DK10FG-6050A2491301-MB-A03 motherboard with missing ACOK voltage. Here are the basic voltages of BQ24725A. The motherboard is dead with no signs of life.
                                          ACN : 19.35V
                                          ACP : 19.36V
                                          ACDET : 2.7V
                                          REGN : 5.916V
                                          VCC : 19.36V
                                          Diode mode to ground reading on ACOK rail is 0.450V on pin 1 of R6013 and 0.230V at pin 2. Replaced BQ24725A a couple of times. Still no luck.
                                          The problem was that I was not having 3.3V/5V from the TPS51225 regulator. So I tracked down to the BQ24725A which was missing the ACOK voltage...
                                          07-21-2024, 12:34 PM
                                        • knk2729
                                          dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
                                          by knk2729
                                          06-23-2025, 07:09 PM
                                        • Hondaman
                                          Windows 11 buying advice needed
                                          by Hondaman
                                          My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                                          She does not want to switch to Linux. And she does not want to use a laptop because...
                                          04-14-2025, 11:35 PM
