BQ24780S (acok missing)
  • benjas11
    • Jul 2024
    • 15
    • Mexico
    Hello everyone, I need your help. I'm having issues with a Lenovo motherboard. When I plug in the charger, there's no current consumption. However, the laptop works if I bypass the charger IC by applying 20V directly to the main resistor. I checked the voltages at the charger IC and found that ACOK (AC OK signal) is missing, and ACDRV (AC Drive) isn't sending voltage to the gates. I've searched for shorts but found none. I replaced the charger IC three times, but ACOK remains around 0.24V–0.35V. The MOSFETs test fine. If anyone has encountered this issue, I'd appreciate your advice.​
  • mon2
    • 14662
    ACOK is an open-drain pin. When the adapter voltage is deemed to be within range by sensing the ACDET voltage to be 2v4 or higher, then the ACOK pin is floated. Because the pin is floating, there must be a mandatory pull-up resistor on this line. Perhaps it is missing.
    Sometimes, the pull-up resistor is to the REGN pin. Sometimes to the 3v3 always on line. Which logic board would you have? Do you have a schematic available? The conditions are ok to enable ACDRV but be sure the DCin mosfets are not shorted.
    Remove all power and measure their resistance:
    source / drain
    source / gate
    gate / drain
    Post each resistance. Repeat for the 2nd dc in mosfet. Each measurement must be hundreds of k ohms or higher else the mosfet is a suspect to be defective.
    If you remove the ~4k ohm resistor that is in series with the gate pin of the 2 x DCin mosfets, what is the voltage of ACDRV without this resistor? Do not lose the resistor.
    This test usually confirms if the DCin mosfets are ok or not. Suspecting that at least one is defective (as per the charger sticky article above by @piernov).
    • benjas11
      • Jul 2024
      • 15
      • Mexico
      This is the schematic, from the motherboard, and according to the ic datasheet, acdetec, acin and regn volts are enough to have the acok in a high mode (3V). And as you can see in the schematic there is no resistance and physically is not present as well. All resistance from the mosfets are above thousands. And what I understand is that acdrive cant exists if the acok is not in high mode.
      • mon2
        • 14662
        Post the schematic of where ACIN is connected. The pull-up should be there.
        what is the voltage to ground of CMSRC?
        • benjas11
          • Jul 2024
          • 15
          • Mexico
          I just realized that i have the same voltage in acok, acdrive and cmsrc around 0.275V. I was confusing acin with vcc. According to ic datasheet, the requirements are, acdetec above 2.4 (i got 2.76). And the vcc of 19V, even regn is 6.00V which means ok. But somehow acok is always under one volt. So if acok is not in high mode acdrive will not send the 25V to the gates.
          • mon2
            • 14662
            Post #2 - Post the actual resistance measurements of the DCin mosfets for a review.
            • benjas11
              • Jul 2024
              • 15
              • Mexico
              Thank you anyway brother, I found a short in the battery side, thank you.
              • bridges_4u
                DK10FG-6050A2491301-MB-A03 missing ACOK
                by bridges_4u
                Hi there,
                I have a DK10FG-6050A2491301-MB-A03 motherboard with missing ACOK voltage. Here are the basic voltages of BQ24725A. The motherboard is dead with no signs of life.
                ACN : 19.35V
                ACP : 19.36V
                ACDET : 2.7V
                REGN : 5.916V
                VCC : 19.36V
                Diode mode to ground reading on ACOK rail is 0.450V on pin 1 of R6013 and 0.230V at pin 2. Replaced BQ24725A a couple of times. Still no luck.
                The problem was that I was not having 3.3V/5V from the TPS51225 regulator. So I tracked down to the BQ24725A which was missing the ACOK voltage...
                07-21-2024, 12:34 PM
              • badcap111
                Xiaomi mi 9T missing resistor
                by badcap111
                Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                Is...
                08-07-2023, 10:42 AM
              • spleenharvester
                Ugreen HDMI splitter missing a pulldown resistor
                by spleenharvester
                Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
                I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
                (Not that this is worth the hassle for an...
                09-15-2025, 11:23 AM
              • pete61
                Gigabyte 4080 Super Gaming OC with a resistor and three caps missing
                by pete61
                Hi all I have got a gigabyte 4080 super gaming oc with a resistor and three caps missing, Can anybody please tell me what the values for these are, See pic for details, Thanks in advance....
                05-21-2025, 09:46 PM
              • motormayhem
                Lenovo T460 Only Charges on One Charger
                by motormayhem
                Laptop Question
                I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                05-12-2023, 01:46 PM
