Acer V5-552g (power?) problem
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 335
    • D12
    Hello everyone.
    I would like to ask you guys for some help about the problem I have with my Acer V5-552g laptop. It's the laptop I bought second hand and it looks like it is defective or not fully functional at best.
    The problem is, laptop only works when on battery and with it's bottom plastic lid of the casing unscrewed and removed. When the lid is on and screwed the laptop presents a rather strange behaviour, from not wanting to turn off to very extremely slow and unresponsive.
    When the laptop is on AC power charger things get even weirder, is either does not want to power on again, or it presents a HDD disk read error (CRTL+ALT+DEL to restart) upon booting past the splash Acer screen. When it's on battery only it boots fine most of the times.
    I did all the usual stuff of checking and changing the BIOS battery, clearing CMOS, 30 sec power drain, new HDD, cleaned and rescrewed the MBO, thermal paste redoing, various versions of MS Wins installed...
    What I am thinking the problem might be is some power converter chip which has problems converting the 19V power from the AC charger to some other voltage (like the 5V HDD uses), but still somehow manages to convert the 15V power the battery gives corretly thus allowing it to boot properly.
    Why the bottom plastic lid screwing on and unscrewing has such an impact of the laptop working (not working when the lid is on, working fine when the lid is off), is a complete myster to me.
    Any help is welcome, I thank you in advance.
  • Seagorman
    • Apr 2017
    • 70
    • Ireland
    Re: Acer V5-552g (power?) problem
    I think you're going to have fun with that one Thermaltake, where do you even start ??? I had a recent job with a Asus laptop that when the case was screw down tightly laptop wouldnt boot but as in your case when case was loosened/Removed it booted fine, in my case it was the area around the powerjack that seemed to be causing the trouble. I carried out a visual inspection on the board with a scope and discovered a hairline fracture just at the back of the power jack, i would put it down to a design fault as the connector was right at the edge of the board with little support, luckily due to its placement the only part of the board effected was the power jack area, I cut the tracks to prevent arcing and jumpered to a non effected area, reinforced the jack with a small amount of Epoxy and all worked fine. You seem to have a hell of a lot of issues with your board but it might be worth checking for damage as mentioned, sometimes a visual inspection may turn up a fracture or a faulty component and save a lot of testing into the bargain
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 335
      • D12
      heh yeah I know, thats why I asked if maybe someone have some similar problems on this laptop or this board.
      I found few things on board that are mabye causing the problem. I will take pictures while disassembling and attach them later.
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 335
        • D12
        I just can't find any problem on motherboard or grounding. I noticed when laptop is powered On without charger plugged in laptop is booting in OS normally, but when I connect AC adapter and power it On HDD disk read error (CRTL+ALT+DEL to restart).
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 335
          • D12
          Got the new power cable still didn't help.
          • Destroyer-Br
            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
            by Destroyer-Br
            I'm working on an Acer Nitro 5 unit with the following specs:
            • Motherboard: LA-J871P Rev: 1B
            • Model: Acer AN515-55-59MT
            • S/N: NHQ7JAL00403906A973400
            • SNID: 03902728734
            Initial Issue
            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
            04-17-2025, 08:18 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Duranitron
            Asus x512dk rev 2.1 power on problem
            by Duranitron
            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
            11-26-2024, 10:22 PM
          • Bonaventure Vigil
            ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
            by Bonaventure Vigil
            Dear All,
            Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
            At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
            12-12-2024, 10:22 AM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
