Hoping someone can help with the following strange problem, Audio works perfectly on Dell Inspiron 15R 5010-1886 when played through its speakers, when headphones are connected sound works OK for a minute or two then becomes very distorted, not the type of problem caused by a faulty headphone jack so most likely to be an issue with the Audio chip output to headphone socket, trying to source Schematics or Openboard View files but looking for possible causes in the meantime, could it be caused by a bad cap in the Audio circuit?, thanks guys
Strange Audio problem onDell Inspiron 15R 5010
Re: Strange Audio problem onDell Inspiron 15R 5010
i had same probem with some acer, speekers works fine, audio jack sunds like some audio filter is on but non of that whas there
i reinstalled system, tried all drivers (it was realtek hd audio, dont remember codecs)
headphone jack was ok, i replaced it anyway, it all remain the same
never solved it... hope you do...Im Back... sort of... -
Must be an IDT audio codec. Drivers are garbage, either you loose your time trying to get it to work, or you just move on.
I've also seen some strange hardware problem with those: audio cutting out after a certain time, or not having audio anymore without any reason. On both Linux and Windows. You should try on both OS first, to make sure it's not a Windows driver issue. Sadly the driver under Linux are pretty bad too so it could still be a software issue if it doesn't work on both.
The only advice I can give you is to use a USB sound card for headphones.
Schematics attached, check if it's the right one.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Tanx for your help guys, dont think its a driver issue as i've tried various revisions, happened on both Windows 10 & now Windows 7 which i've downgraded to, as its my own Laptop and its not a huge problem the USB Sound Card seems like a very good option, can pick them up for little or nothing too, tanx again guysComment
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
by falcontechGood Afternoon
I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...-
by estabilitoI have problem with probook 650 g2 - laptop shows connected headphones Even without them. If i pług headphone Jack - computer show disconnected headphones. Speakers work when i change sound output.
I replaced Jack board - nothing changed. Computer shows connected headphones even without Jack board connected to motherboard.02-01-2023, 12:51 PM -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by mohamed mmHi,
I've an Inspiron laptop model 5520, board name, la 8241p, with a 7-beep problem.
exist voltage:
PL 200:3.3v
PL 201:5v
ram volt PL300: 1.5v
PL600: 0.9v
PL500: 1.0V
PL 202: 19V
Processor section:
PL701: 1.2V
PL702:1.2V
but PL704: 0.0V
and PQ705 / PQ706 are zeros on gate/drain and source.
PC724/PC712 : 19V.
bios volts:
EN25QH16 / EN25Q32B: 3.3v.
I tried to program a (W25Q32B) BIOS chip with an (EN25Q32B) BIOS dump from the internet, but during verification, it says... - Loading...
