Dell n5010 dg15-09909-1 mb
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    No apparent shorting on the mb. no 3v/5v present. I replaced PU4601(51125) and replaced sio still same. Pin23 of 51125 is not giving 3v powergood signal. I injected 3v from psulab , no componenet heated up.
    On ething i have noticed is that resistance connected to pin23 of 51125 shows 2.2k whwereas it should so 97k approx. If vi remove the ic resistance rating becomes 97.
    I have tried putting up 51125 from working mobo and after soldering the ic resistance shows 97k. the moment i give power to mobo resistance shows 2.2k.
    What can be wrong??
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    Re: Dell n5010 dg15-09909-1 mb
    You have LDo voltage, around the power IC 51125 .....3.3v and 5V found...if not change 51125 Ic ...
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Thanks for your reply razu. The problem is i dont have 3v/5v on this mobo. I have tried changing the following ic's
      01. 51125
      02. 51116
      03 charging ic
      04. Sio
      Still no 3v/5v. I have checked all the mosfets-nothing abnormal and my power board is tested ok.
      Checked resistors near all ic's and seems to match with schematics.
      Wondering why 3v/5v power ok signal is not enabled on 51125.
      Can anubody guide me the preconditions to enable 3v/5v pok signal on 51125??
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • minaedward
        Dell N5010 keyboard
        by minaedward
        Hi all
        I have a dell n5010 that shows black screen after the dell logo and freezes
        But when I remove the keyboard it works fine and boot the windows
        The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
        But after the dell logo it causes the laptop to freeze
        Any ideas why ?
        09-29-2024, 05:24 PM
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
