Dell 3521(la9104p).its giving 7 beeps.thats means cpu core supply is not generation.i have changes isl95833 than also same problem.plz help
Dell 3521 LA9104p.cpu failure
Tags: None
Re: Dell 3521 LA9104p.cpu failure
THanks but problem solved.it was not pch or cpu.1.2k resistor open.it took lots of time to find outComment
Can you upload and show the image of tje resistor please?thanksComment
dell 3521 la9104p laptop not charging, charging ic good. 2 second detect charging after descended charging, lap working power adapter & battery. how to fix charging problem
plz help meComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by ThemiI have this laptop a dell XPS 13 9310
Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure
I believe this is the spec from using micron tool to decode marking
Images of the ram
I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
Another...11-24-2024, 09:06 AM -
Dell Inspiron 3521 15" Laptop Schematic & Board View...
Channel: Schematics and Boardviews
by hobostoveI have a Dell gaming laptop here with a blink code of 3 red, 5 blue (power rail failure). 3V and 5V are present, but 1.8V is missing. I looked at PU1801 according to the schematic, and it's not receiving an enable signal. Any ideas where to check next? I think that signal comes from the PCH.
No obvious shorts under thermal (or probed), damaged components, liquid, etc.
Board: LA-K472P
Link to post with schematic -
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... - Loading...
