Dell 3521(la9104p).its giving 7 beeps.thats means cpu core supply is not generation.i have changes isl95833 than also same problem.plz help
Dell 3521 LA9104p.cpu failure
Tags: None
Re: Dell 3521 LA9104p.cpu failure
THanks but problem solved.it was not pch or cpu.1.2k resistor open.it took lots of time to find outComment
Can you upload and show the image of tje resistor please?thanksComment
dell 3521 la9104p laptop not charging, charging ic good. 2 second detect charging after descended charging, lap working power adapter & battery. how to fix charging problem
plz help meComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by puccovelliHi all, I hope this is the right place to post.
I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
1] Could someone confirm what the component that has blow actually is (and where I could get another from).
2] Whether this component is likely to cause the RAM failure issue, and if replacing... -
by jasonbay13it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
PU200
pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
pin 8 vreg3 = 0v
pin 13 en = .2v
pin 1,6 entrip1,2 = 0v
b+ and b++ = 19.5v
+5valw = 0v & 25+ohm to ground
+3valwp = 0v & 25+ohm to ground
i cleaned the board up just a little and can get more pics.
where should i be looking? thx... -
by PeteHHi everyone,
I have here a broken Dell Precision 5520 / LA-E331P r2.0 to play with
I found the schematics for r1.0, but not for r2.0.
The situation
- the laptop turns on, but the screen stays black -> the dell diag-LED shows the blink pattern for "CPU failure"
- the voltages close to the CPU stay at low
- I don't see any hotspots on the PCB (thermal imaging camera)
- some spots/areas on the PCB indicate some kind of liquid "damage"
Before I start digging though 70+ pages of schematics, maybe somebody... -
by ThemiI have this laptop a dell XPS 13 9310
Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure
I believe this is the spec from using micron tool to decode marking
Images of the ram
I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
Another...11-24-2024, 09:06 AM - Loading...
