Hp cq56-129 nr no power problem help urgent
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    this motherboard have no 3v and 5v. I change RT8206B but no result .. write the bios same condition.
    I write here power IC voltage . Please any one can help
    IC RT 8206B
    pin 1 - 2.00 V,
    2-0,
    3- 4.96,
    4- 15.59,
    5 - 0,
    6- 20.8,
    7 - 4.9,
    8- 0,
    9-0,
    10-0,
    11-0,
    12-1.1,
    13-0,
    14-4.8,
    15-0,
    16-0,
    17-4.9,
    18-4.9,
    19.4.9,
    20-4.9,
    21-0,
    22-0,
    23-0,
    24-4.5,
    25-0,
    26-0,
    27-4.8,
    28-0,
    29-0,
    30-0,
    31-1.1,
    32-0 volt
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: Hp cq56-129 nr no power problem help urgent
    Check S5_enable signal from SIO. Then tell me the result.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      Seem OVP. Try replace caps with tantalum
      • razu
        • Jan 2015
        • 218
        • Bangladesh
        without SIO supply 3.3 input voltage , how can i find S5 Enable voltage .............
        • kiraro
          • Jan 2016
          • 177
          • North NY
          IC RT 8206B
          pin 1 - 2.00 V,
          2-0,
          3- 4.96,
          4- 15.59,
          5 - 0,
          6- 20.8,
          7 - 4.9,
          8- 0,
          9-0,
          10-0,
          11-0,
          12-1.1,
          13-0,
          14-4.8,
          15-0,
          16-0,
          17-4.9,
          18-4.9,
          19.4.9,
          20-4.9,
          21-0,
          22-0,
          23-0,
          24-4.5,
          25-0,
          26-0,
          27-4.8,
          28-0,
          29-0,
          30-0,
          31-1.1,
          32-0 volt
          Hello,check PQ44,PQ45,PQ46,PQ49 ,if there are ok ,check the feedback line (for 3V =PR94,PR97,for 5v= PR79,PR77) if all ok check if there is a short in one of the 3v line and 5v line.
          hope that help you .
          • subroto
            • Oct 2015
            • 230
            • Bangladesh
            Pin no. 32 must have some value. check the PR96. I think it is the culprit.
            • subroto
              • Oct 2015
              • 230
              • Bangladesh
              one side of PR96 is connected with pin no.32 and another side with +5V_VCC1. Check this part carefully.
              • razu
                • Jan 2015
                • 218
                • Bangladesh
                After all I found 3v and 5v but another problem 3.3v drop to 1.22 volt but 3.3v coil was no short ......... and switching volt is 3.3v....
                power ic is hot
                what can i do now
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
                • SDNarcia
                  Dell 15R-5521 keyboard problem (KBC?)
                  by SDNarcia
                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                  As additional information,...
                  07-20-2024, 10:47 PM
