Hp cq56-129 nr no power problem help urgent
    this motherboard have no 3v and 5v. I change RT8206B but no result .. write the bios same condition.
    I write here power IC voltage . Please any one can help
    IC RT 8206B
    pin 1 - 2.00 V,
    2-0,
    3- 4.96,
    4- 15.59,
    5 - 0,
    6- 20.8,
    7 - 4.9,
    8- 0,
    9-0,
    10-0,
    11-0,
    12-1.1,
    13-0,
    14-4.8,
    15-0,
    16-0,
    17-4.9,
    18-4.9,
    19.4.9,
    20-4.9,
    21-0,
    22-0,
    23-0,
    24-4.5,
    25-0,
    26-0,
    27-4.8,
    28-0,
    29-0,
    30-0,
    31-1.1,
    32-0 volt
    Re: Hp cq56-129 nr no power problem help urgent
    Check S5_enable signal from SIO. Then tell me the result.
      Seem OVP. Try replace caps with tantalum
        without SIO supply 3.3 input voltage , how can i find S5 Enable voltage .............
          IC RT 8206B
          pin 1 - 2.00 V,
          2-0,
          3- 4.96,
          4- 15.59,
          5 - 0,
          6- 20.8,
          7 - 4.9,
          8- 0,
          9-0,
          10-0,
          11-0,
          12-1.1,
          13-0,
          14-4.8,
          15-0,
          16-0,
          17-4.9,
          18-4.9,
          19.4.9,
          20-4.9,
          21-0,
          22-0,
          23-0,
          24-4.5,
          25-0,
          26-0,
          27-4.8,
          28-0,
          29-0,
          30-0,
          31-1.1,
          32-0 volt
          Hello,check PQ44,PQ45,PQ46,PQ49 ,if there are ok ,check the feedback line (for 3V =PR94,PR97,for 5v= PR79,PR77) if all ok check if there is a short in one of the 3v line and 5v line.
          hope that help you .
            Pin no. 32 must have some value. check the PR96. I think it is the culprit.
              one side of PR96 is connected with pin no.32 and another side with +5V_VCC1. Check this part carefully.
                After all I found 3v and 5v but another problem 3.3v drop to 1.22 volt but 3.3v coil was no short ......... and switching volt is 3.3v....
                power ic is hot
                what can i do now
