Hp G6 Core i5 turns off after 10 seconds
 Re: Hp G6 Core i5 turns off after 10 seconds
 Passete ; If you picked a 100% working fan from another mobo , pay attention that the wires coloring do differ from one fan to another , even from one HP to another one . If by coincidence there were two white wires , it doesn't mean they are by standard , carrying the same voltage .
 Don't worry experimenting anyway . The only bad thing you can get if any , is a bios warning about an incompatible fan .Comment
 Thanks, but i used exactly the same fan, from another HP, 4 wires same colors.Passete ; If you picked a 100% working fan from another mobo , pay attention that the wires coloring do differ from one fan to another , even from one HP to another one . If by coincidence there were two white wires , it doesn't mean they are by standard , carrying the same voltage .
 Now i need to find exactly the same KBC, "ENE KB3940QA1"
 all the ones that i have here doesn't match this model.Comment
 Maybe this site can be of help :
 http://www.electronic-circuits-diagr...679860207.html
 As long as the fan isn't working , do not risk it too much , and good luck .Comment
 I've found a seller that sels just 1 piece for about 3 dollars with free shipping, but many chinese people are in vacations Now, need to wait until february.Maybe this site can be of help :
			by zklgfsHi,
 I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
 08-11-2025, 02:14 PM
			by twonk9098Hi all,
 I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
 I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
 I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
 I have tried a few new bios but exactly...
			by Rick_1234Good evening, gentlemen.
 I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
 To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
 https://drive.google.com/file/d/1L6S...ew?usp=sharing
 Things I tried
 - Bought a new AC adapter thinking that was the problem but the problem...-
			by Kambi13Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
 Not heat related, everything is ok regarding to that.
 All voltages are present.
 Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
 Motherboard is Cedar 13269-1 F3XMC Rev A00...
			Hello. Could anyone help me with that problem.
 Laptop model: Acer Nitro 16 AN16-41
 motherboard: DAZGUMB1AD0
 It had liquid contact and owner dried it up. Dried it so hard that keyboard is all wavy...
 I've found one drop on motherboard near B+ capacitor, it wasn't short.
 But motherboard works exactly 60 seconds and turns it self off. Not overheating just exactly 60 seconds. Normally I would say its ME Region problem, but CPU is AMD...
 In case im attaching BIOS backup
- Loading...
