lenovo flex14 -nopower
  • ghoshiry
    • 90
    • iran
    hi to all
    i have a lenovo flex14 and dont power on
    voltage 3.3 and 5 is ok and fix
    when i push power key one moment on and off fast
    pls help me if you have this problems
    tanks:vio
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: lenovo flex14 -nopower
    try without battery and see if it fires.
    • ghoshiry
      • 90
      • iran
      i try withe battery but not work
      • ghoshiry
        • 90
        • iran
        any one have this model Schematic?
        • khaahk
          • Dec 2013
          • 751
          • Estonia
          Try a good power adapter, if adapters center pin is not connected then the behavior might be like that. If no good apapter at hand use 500kOhm resistor from id pin to gnd to simulate Lenovo smart adapter.
          • ghoshiry
            • 90
            • iran
            adapter is good and ok-when battery is conected led light for battry is on
            but dont power on
            • JDong
              Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU 831A laptop
              by JDong
              There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
              • Laptop Model: Lenovo V15 G4 IRU
              • Issue: Forgotten supervisor password.
              • BIOS Chip: GD25B128E (or GD25B128B
              07-06-2025, 10:18 PM
            • rumpumpel1
              Lenovo X13-Yoga Gen 1: hibernation problems
              by rumpumpel1
              I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
              11-03-2024, 12:31 AM
            • myty6
              BIOS problems Slim 7 16IAH7 Laptop (Lenovo) - Type 82VB
              by myty6
              Hello Everyone,
              Make : Lenovo
              Model: Slim 7 16IAH7
              S/N: YX04XNTW
              Mfg: 2022/09/13
              System will not boot. I have tried the normal troubleshooting (external display, unplugged batter for 24hrs, holding the Novo button, tried to boot from usb using every typed of bootable media) i cannot get a display but keyboard backlight lights up but it's not responsive, fans spin and power button flashes but stops. After researching my symptoms, I am leaning towards a bad bios.
              I have identified what looks to be 2 bios chips on my motherboard, both winbond...
              08-28-2024, 02:41 PM
            • clabr
              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
              by clabr
              Need help to solve some problems with this laptop.
              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
              Before this had happened I observed some other problems:
              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
              12-02-2021, 08:09 AM
              Lenovo 3000 Series Schematic
              Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
              3000 C100 laptop with Braille keyboard
              Lenovo 3000 C
              C100, C200 - 15-inch XGA screen
              Lenovo 3000 N
              N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
              N500 - 15.4 inch screen.
              Lenovo 3000 V
              V100, V200 - 12.1-inch WXGA models
              Lenovo 3000 G
              G400, G410, G430, G450, G455, G510, G530, G550, and G560...
              10-04-2024, 06:05 AM
