Lenovo G70 Screen backlight
  • Bibbles
    • Dec 2016
    • 31
    • England
    Hi, i have an issue with a Lenovo G70. It has had liquid spilled on it and as a result there was corrosion over the components in photo. At first the screen would brighten when the on screen slider was pulled into the dimmest position and dim when the slider was pushed in the opposite position. After cleaning the area with isopropyl alcohol and a soft cloth very gently the screen is permanently dull and no adjustment is possible. On the other side of the board from the damaged area is the screen cable so i am assuming that the components relate in some way to the screen issue. I think it may be a damaged / blown fuse. Could i ask if anyone could help in identifying the components and whether the issue is in fact anything to do with a fuse or otherwise.
    Thank you in advance.
    Regards Dave
  • VaNDAL_UK
    • Aug 2010
    • 77
    • United Kingdom
    Re: Lenovo G70 Screen backlight
    The fuse is the one with a 0 on it.
    • Bibbles
      • Dec 2016
      • 31
      • England
      Thanks for the quick reply, have tested and there is continuity? Cant be that that's the problem. I was thinking it was the one next to the arrow as this doesn't have continuity. Have you any iseas what may be causing the issue?
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        That's a cap and clean up the board i have added a schematic goto page33
        and check.
        • Bibbles
          • Dec 2016
          • 31
          • England
          and check.
          Thank you. As i am a complete novice and cant read the drawing you provided, i wondered from the information i have given in my original request whether you could offer identification of the parts in the photo and what reading they should have if they were working correctly. I hoped the fact that the brightness worked in reverse prior to cleaning may give a qualified person a clue.
          Regards Dave
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            If C15 have short/contiunity from pin 1 to pin 2, there is a chance R17 has open. B+ is Main voltage from AC/DC. from adapter 19V, from Battery 12V (depend value rate in battery case)
            clean the board, remove and check C15, don't forget to check contiunity to the pad of C15 as well. if shorted has gone, replace R17 (if already open)
            • Bibbles
              • Dec 2016
              • 31
              • England
              Thank you so very much for this information. I will have a go over the weekend.
              Cheers
              • Bibbles
                • Dec 2016
                • 31
                • England
                I have thoroughly cleaned the board with isopropyl alcohol.
                Hi i have checked as best i know how. I have power to both sides of R17 and continuity. I also have power to the top side of C15 Yellow arrow but none at the black arrow side or continuity. Does this help at all. PS what do you mean by remove and check C15, i can remove but what am i checking for? Thanks again for your help.
                Dave
                • Bibbles
                  • Dec 2016
                  • 31
                  • England
                  and check.
                  Hi, i have done some research and had help from another forum member. I have discovered that the capacitor (C15) is giving out a reading of 560 on the 2K scale on my multimeter. Occasionally it gives out 480, but very rarely. Could i ask what is the capacitors supposed value and if not correct where would i find a replacement.
                  Thanks again.
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    Dave
                    So, B+/LEDVDD have no problems. Even without C15, the circuit should be working fine. Maybe the real problems was related with BKOFF# / DISPOFF# signal and INVT_PWM signal
                    you can read as reference here:
                    https://sites.google.com/site/lcd4ho...-led-backlight
                    https://sites.google.com/site/lcd4hobby/lvds-cables
                    • Bibbles
                      • Dec 2016
                      • 31
                      • England
                      Thank you for your help. I have been very busy sorting other work related items, i will take a look shortly and report back any results.
                      • MadalinJula
                        Madalin
                        • Dec 2016
                        • 8
                        • Romania
                        hi,
                        can you help me with the bios for G70-80?
                        ailg1 nm-a331 rev 1.0.
                        Thank you in advance!
                        Have a nice day!
                        • coasterghost
                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                          by coasterghost
                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                          System Hardware:
                          Processor: AMD Ryzen 7 PRO 5850U
                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                          09-08-2025, 10:46 PM
                        • Noursa
                          Lenovo Yoga C940-15IRH No primary Screen
                          by Noursa
                          Hello
                          I'am a beginner in electronics repair and i got some trouble to find what's goning on a computer. It is a lenovo yoga C940-15IRH laptop and the screen doesn't work anymore, but that work on an external one
                          the screen seams to be hard to unbuild properly so i want to test it by other way
                          how can i be sure if the signal is really send to the screen ? i did some check on screen connector on LCD1 got 19v and on MiC1 connector on the other side of the screen (dunno if it's for the screen itself or other thing) got a lot of 3.2v pin
                          did u got...
                          05-04-2024, 10:00 AM
                        • VcemPzd
                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                          by VcemPzd
                          Hello everyone !
                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                          04-28-2025, 10:14 AM
                        • wizard13
                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                          by wizard13
                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                          • Part Number (P/N): PYU13E-00C00PFR
                          • Serial Number (S/N): 22028896H
                          • System Configuration (SC): A1PYU13E1127
                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                          • Power Input: DC 19V –
                          02-28-2025, 02:43 AM
                        • shahnld
                          Lenovo legion 5 pro startup issue
                          by shahnld
                          Good day Experts
                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                          08-24-2025, 12:31 PM
