Dell inspiron 14z usb port fuse
  • drazy004
    • Oct 2015
    • 16
    • NIGERIA
    Does anybody know how the USB polyfuse/resettable fuse is implemented in a dell inspiron 14z 5423? Mine suffered a USB port short sometimes ago(power surge has occured on this port blah blah). After that, I could no longer connect my phone storage or flash drive to the USB port, but the port was still supplying as I could charge my phone, and as well confirmed with a DMM. I unplugged the laptop and removed the battery as well as the CMOS battery and left the board lying for a day before putting it back together. It worked. Couple of hours later, same thing happened again, but this around the original fix failed to work, even after abandoning the laptop for about a week! The DVD player is bad, otherwise I could have tried to format the system with Windows.
    I've tried reinstalling the drivers to no avail, even the enhanced host controller, still same outcome. In some other laptops I've worked on, the fuse is very explicit, and I've had some success simply bridging them appropriately or swapping them out. But this motherboard doesn't seem to have a clearly defined fuse component on the USB line.
    Any assistance will be greatly appreciated.
  • R_J
    • 9607
    Re: Dell inspiron 14z usb port fuse
    Is'nt the fuse in the +5volt line? and if you are getting 5 volts I would think the fuse is ok. most likely would be the usb controler chip at fault
    • drazy004
      • Oct 2015
      • 16
      • NIGERIA
      Thanks @ R_J. Yeah I can actually get 5 volts. So you are suggesting it could be a problem with the usb controller chip. How do I go about testing that?
      • drazy004
        • Oct 2015
        • 16
        • NIGERIA
        • R_J
          • 9607
          Get out the scope and check for data on the i/o lines, I don't know how else you can tell if the chip is working.
          • drazy004
            • Oct 2015
            • 16
            • NIGERIA
            I'll update as soon as I do that. I've not been able to carry out any further tests since the last time
            • drazy004
              • Oct 2015
              • 16
              • NIGERIA
              Sorry for the late update guys. I tried tracing the schematics to no avail. The data line for the usb hub has been quite tough to trace for me. In the interim, I managed to do a system format using Windows. Still usb devices are not getting detected even though they do get power from the ports.
              Thanks for any headups
              • drazy004
                • Oct 2015
                • 16
                • NIGERIA
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                • Calum McConnell
                  Dell Lattitude 7424 Broken USB-C Port
                  by Calum McConnell
                  Hello!
                  I run a dell rugged extreme as my main computer, and have linux installed. All is well! However, after plugging in a friends power adapter to test it (it turned out to be broken), my USB-C port has stopped working. This isn't the end of the world, since I can still charge with a good old-fashoned 19V barrel power, but I'd like to fix it.
                  The port shows up to the operating system, but does not provide power to devices plugged into it, nor can it receive power. I have tried cleaning it.
                  I strongly suspect that the physical port itself is damaged, and would...
                  12-02-2024, 05:24 PM
                • computerbacon79
                  Dell Inspiron 3480 All in One corrupt Bios issue
                  by computerbacon79
                  The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                  05-06-2025, 06:43 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • GadgetsFix
                  Dell Inspiron 16 5630 BIOS request
                  by GadgetsFix
                  I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                  • Model: Dell Inspiron 16 5630
                  • MainBoard Part Number: 4550SC01C004
                  • Laptop Serial No: GKH3JX3
                  • DP/N: 0303KM
                  • QUAKE N RPL UMA CS MB
                  • 213251-2
                  • TMN0H$KB
                  01-17-2025, 07:38 AM
