Using a different battery to test a Samsung N900V
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Using a different battery to test a Samsung N900V
    I have some stuff here called Adhesive Remover that is quite potent and good at removing epoxy. I believe denatured alcohol is good too.
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      Heat did the trick! I was shocked. I went down, my wife was already heating it. I told her to stop and I covered everything with tin foil. We left to go to Autozone. They didn't have our part (they did, but it was set aside for someone who ordered it so we couldn't get it). We bought brake cleaner but didn't use it. I put the heat up to 500F and just put it on for a small bit of time. I thought it wasn't working yet. I went to put the pliers on it, just so when it got warm enough, I could lift it off, and it just came off, right then and there! I only had the heat on for maybe 30 seconds.
      Now I gotta clean the stuff off the processor. I'm going to need to purchase some for when I put the new chip on. Any ideas what it might be called and where I could get some? Something that is thermal paste but would also hold it on like glue.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • Spork Schivago
        • Mar 2012
        • 4734
        Now that we have the heatsink off, we need to remove the white stuff from the chip, to read what it is. It's an MTK (MediaTek) MT8202(something). That something might be important. The schematics says MT8202E, but on e-bay, I can only find an MT8202AG. I've tried other sites. Some place called Alibaba had some MT8202E's but wanted me to buy 5 of them for 50$. E-Bay wants 16$ for the 1. What's weird with the Alibaba site (might have been Aliexpress), when it was set to the French site, it found it, but when I set it to the English site, none available. Almost like they're showing different products based on what country you live in.
        E-Bay has it from a China seller, so it can take a very long time to get here.
        We tried 70% IPA (Isopropyl Alcohol) and that didn't work so well. She switched to a bottle of Un-du she bought at her work. The MSDS for Un-Do shows the ingredients as Naphtha (Petroleum), Hydrotreated Light. Not sure what hydrotreated light is or how they store that in a bottle! Maybe they mean hydrotreated light was used on the Naphtha. So, essentially, it's a 4 ounce bottle of Naphtha at like 1000% the cost of Naphtha. We really need to purchase some plain old Naphtha. Wonder if Walmart carries that.
        • Spork Schivago
          • Mar 2012
          • 4734
          My wife ended up cleaning up the chip, it is an MT8202AG by MediaTek (MTK). From the service manual, it appears I'm going to have to download the firmware from the chip somehow and upload it to the new chip. Not sure how to do that if the TV doesn't turn on. That's for the TV repair thread though (I've been talking about it over there). Because this is the phone forum, aren't there a lot of MediaTek or MTK chips in Android type phones?
          Has anyone used that MTKTool before?
          • diif
            • Feb 2014
            • 6978
            • England
            Yeah, I went to Aliexpress last night and got the French version, occasionally I get the Russian version.
            You want some thermal paste like this http://www.ebay.com/itm/CPU-GPU-Ther...-/141918232588
            A bit thicker than normal thermal paste and it sets hard.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              i saw this online
              Upgrading with Mtk Tool
              Mtk Tool is a green program need no installation. It is saved in the folder [MTKTOOL_20061027]. There are five folders/files in this folder altogether. The MtkTool using log is restored in the MtkLog folder. It records the running time and date whenever the tool is used. The log will be a txt file named by date and time.
              After connecting the TV to PC, double click the MtkTool.exe icon, open the file. If any error appears, it means the related port is not set properly. Ignore these errors, click 'confirm' and enter the MtkTool main interface.
              Flash chip model.
              The port through which the PC communicate with the chip.
              The communication baud rate.
              The new program file (*.bin) for upgrading.
              Click this button can select the *.bin file to be used for upgrading.
              Click to start upgrading.
              Open 'Device Manager' and find which port is connected with the TV. Select the right baud rate according to chip model. For this unit; chip model is MT537X, select 115200*2. Where of not click the "Auto set Flash Baud rate" in the window menu depends on the chip type. If flash chip does not support, do not select this option; otherwise, reverse the selected mood.
              Click 'Brows' button, find the upgrading program file and select it. Press 'Upgrade" and start upgrading.
              After upgrade, 'Upgrade sucessful' massage will be displayed.
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                Sorry, what do you mean the French version and occasionally the Russian version? Version of what?
                I was thinking something more like this:
                http://www.arcticsilver.com/cmq2.html
                Or this:
                http://www.arcticsilver.com/arctic_alumina.htm
                I've used one of those before diif, I can't remember which one. It was made by Arctic Silver and I didn't realize that it wasn't really made for CPUs. It was a ceramique type of compound but it wasn't a permanent attachment. It was almost permanent, you know, it took a bit to get it off. I don't want something that will never come off, just something that would take a bit to come off, you know what I'm saying? That stuff you linked to, do you think that would come off with some pressure? That's the stuff I'm looking for. Something that isn't impossible to remove, just something that will hold it until someone tries pretty hard to get it off, just in case someone ever has to work on it again....
                I've always liked the AS stuff, but if the stuff you linked to is better, I'll purchase some of that.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  The French and Russian versions of Aliexpress.
                  Both of the compounds you suggest are for CPUs which suggests to me they won't set. Not what you want when the heatsink and processor are vertical.
                  AS do do a two part thermal epoxy, but the stuff i suggested works just as well and is a fraction of the price and easier to apply, squeeze from the tube, no mixing required.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #29
                    Good to go. Have you used the stuff you're recommending before? If so, can we remove the heatsink later on if we need to, using heat like we did this time or something? Or is it one of those once it's on, it's on for good?
                    At this point, I think we're going to replace the entire board. The chip is around 16$ plus shipping. The board is around 21$ plus shipping. Just want to make sure the board is 100% compatible. I'm thinking if I'm replacing the board, maybe I'll pull the chip on this board and redo the solder balls, just to see if that fixes it, you know?
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • SluggerB
                      Help with trying to fix phone that is not charging (Pics inside)
                      by SluggerB
                      I have two TCL A30 phones.
                      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                      New Phone: Works fine, bought as a donor board to try and repair Old Phone
                      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                      08-12-2024, 08:11 AM
                    • mkdj
                      ASUS X571 no power : battery issue?
                      by mkdj
                      Mark and model: ASUS X571
                      Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                      Tests already made:
                      - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                      - I have removed...
                      07-14-2025, 09:16 AM
                      09-07-2024, 05:50 AM
                      Brother “P-Touch” PT-2040SC modified with metal hydrate AAA 700 milliampere hour battery pack originally for cell phone
                      by sam_sam_sam
                      I have gotten so tired of battery cells leaking and it happen to this device and it is not very old I had bought these battery packs from The Electronic Goldmine for $1.00 a pack when they had a sale and I am putting 3 packs to good use so I do have to deal with leaking battery cells I am over it
                      I bought the label maker at Sam Club a while back for $29.99 it come with 4 cartridges and they had them on sale again for $29.99 again so I bought another one because I was not sure if I was going to able to get it to work on the battery cells that I had planned on using for this particular...
                      05-26-2024, 10:44 AM
