Samsung NP900X3C-A01AU / Sandisk U100 128GB loses partitions after cold boot
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Daughter's notebook was running Windows 10, albeit with irritations, before she decided to clean install Win10 Pro x64
    Now, after a cold start, it just comes up with Phoenix boot loader, default prompting Sandisk U100 128GB
    If Win10 install USB key is inserted prior to cold start, Phoenix UEFI boots into Win10 install, then selecting Custom install says there's ~119GB of unallocated space and will happily install on it
    After install, everything looks good, can warm restart without problems, Disk Management reckons there's a 450MB recovery partition, a 99MB UEFI partition, and a >118GB partition
    Running Samsung's BIOSUPDATE.EXE reckons UEFI is up to date (P07AAC), and Sandisk's Dashboard says SSD's firmware is up to date (10.56.04)
    But turn it off, there'll be a repeat of Phoenix boot loader
    Last thing my daughter did, before this problem started, was run Sanitize from Sandisk Dashboard, which asks for a USB key which it sets up then needs to boot - apparently it came up with a problem about Secure something
    The plot thickens if I try SSD_Memory_Cell_Clearing - don't get too far, step 1 "hdparm -I /dev/sdX" shows Frozen
    BTW, it's not just Win10, same problem if Win7 or Win8.1 is installed
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung NP900X3C-A01AU / Sandisk U100 128GB loses partitions after cold boot
    Sounds like a UEFI issue and Secure Boot settings.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Already gone down that path - unlike some of the stuff I've found related to NP900X3C, this version of BIOS/UEFI doesn't seem to have Secure Boot option - see attached
      • highpulse
        i hate HP
        • May 2013
        • 1489
        • portugal
        yes it has , you need to introduce a supervisor password , then leave bios , and re enter again , some functions will now be visible , dont forget in the end to remove supervisor password
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I tried that after finding a clue in an Acer document
          Still couldn't get it to work, also not when I tried again now, just after midnight
          However I have downgraded BIOS from P07AAC to P04AAC (easier said than done), and when I tried first with P07AAC didn't leave BIOS and re-enter again
          Will restore P07AAC later and try again
          Thanks for your help
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Before restoring P07AAC, I downgraded from P04AAC to P03AAC and tried setting Supervisor password, then exiting, then re-entering Setup - no sign of a Secure Boot option
            So then I restored P07AAC - Supervisor password was still there, but no Secure Boot
            Tried clearing Supervisor password then re-doing above - still nothing
            In the meantime I discovered my brother-in-law has a NP900X4C with firmware P03AAC running Windows 7, and there's no Secure Boot option in his Setup either
            Is it possible Samsung/Phoenix has automated Secure Boot handling depending on Operating System like they've done with AHCI, but unlike auto AHCI they don't offer a manual override ?
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              FIXED
              Bought used Toshiba THNSNJ256GMCT from eBay
              First time I started notebook after fitting, it showed a partition
              After DISKPART/CLEAR, an install of Win10 went without a hitch (just like with original Sandisk), except this time it was still OK after a shutdown
              Now waiting on mSata adapter so I can try the Sandisk in a real computer
              • privato89
                Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                by privato89
                I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                Let's begin:
                Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                03-26-2024, 06:37 AM
              • claws77
                FX553VE-DM318T(FX553v) not POSTING
                by claws77
                Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
                Gpu - nvidia geforce 1050ti
                Ssd orion o700
                Hdd hgst721010A9e630
                See images
                What's not working right?
                The system does not even POST, display is black,
                LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
                When did the problem happen?
                My laptop had dual boot setup, ubuntu and windows 10.
                It already had a moklist error, that would occur when i tried to boot ubuntu.
                05-17-2025, 04:09 PM
              • Luke Anders
                Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                by Luke Anders
                A few details about the laptop itself:
                Name: Lenovo Legion 5
                Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                BIOS Version: GKCN60WW
                EC Version: GKEC65WW
                Serial Number: PF39AQ7Z
                Board Model: NM-D562 Rev 3.0
                RAM: 16GB Installed, DDR4 (brand new)
                NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                I bought this laptop recently from eBay as a faulty device....
                10-12-2024, 05:13 AM
              • hinisa
                Xiaomi router freezes at boot after re-capping
                by hinisa
                I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                07-08-2023, 05:58 AM
              • NolesFan
                Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                by NolesFan
                Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                10-24-2024, 06:36 PM
