gtx670m on asus g75vw Mhz issue
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    I have a problem with a motherboard for a asus g75vw, after installing a video card gtx670m it seemed to work but after checking the performance stops 300 Mhz.
    The same video card with another motherboard identical to the first, and with the same hard disk, it works perfectly at maximum speed.
    What could be the component that creates this problem?
    thanks
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: gtx670m on asus g75vw Mhz issue
    does it have 3 heatpipe ? is it a 100 watt dissipation system? gpu-z log with vcore, temperature and so on ?
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      The gpu temp is ok (40 C to 50 C too low ?) , video card work well in another mobo with the same heatsink and bios chip, power adaptor is original with correct watt, the cpu is the same. Only difference is about mobo version:
      Mobo ok is asus g75vw rev 2.1 mobo with Mhz stuck is g75vw rev 2.4.
      It's possible a power problem, low amperage on mxm socket ?
      • MakNCheese
        ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
        by MakNCheese
        I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
        Symptoms:
        • Severe lag across the system, including BIOS navigation.
        • Slow boot times and unresponsive performance in Windows.
        • Battery charges very slowly (e.g., ~5% in 2–3 hours).
        • No error messages or BSODs, just extreme sluggishness.
        What I've Tried:
        • Replaced
        06-04-2025, 12:48 AM
      • lukkihapsi
        Asus Vivobook X515JA Weird Boot Issue
        by lukkihapsi
        Asus Vivobook X515JA Laptop
        Issue :
        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
        Tried :
        Cleaned inside for dust, applied fresh thermal paste. No Change!
        Removed keyboard, Trackpad, fingerprint sensor. No Change!
        Removed Internal SSD. No Change!
        Updated BIOS to latest version. No Change!
        Removed battery and pressing power button for 1 minute. No Change!
        Weird Part :
        Upon turning laptop ON, screen lights up - stays black,
        I...
        07-07-2025, 12:07 PM
      • ZixuTech
        Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
        by ZixuTech
        Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
        Perhaps BIOS issue?
        Brand: Asus
        Model: F1502Z
        SN: R4N0CV11S622169
        Board: X1403ZA 2.2
        I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
        Can you clean and enter SN for me please....
        03-31-2025, 05:04 PM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • Safio
        Asus Rog Strix g15 g512LI BOOT ISSUE
        by Safio
        Hello
        My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
        i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
        thank you
        06-08-2024, 08:43 PM
