Dead Bay Trail SOC? Compal la-b481p
  • luke10050
    • Mar 2013
    • 209
    hey, i have a 15" inspiron with a bay trail SoC. it seems like the soc is bad as even in an S5 state the SoC gets extremely hot. i have 5VALW present and 3VALW, noticed the RTC circuit was shorted too and it seems to only go to the SoC (RTC not populated on this PCB). i do also get 1.35V for the dram if i press the power button. but no SoC_VCC
    Just curious if anyone's seen bay trail SoC's die. if it were working correctly i'd at least expect it to keep cool when its not on.
    edit: i should clarify the SoC gets EXTREMELY hot even in an s5 state. all voltages appear normal however i was not getting any signs of life with the RTC circuit connected (RTC circuit pulling 3VLP down to about 1v).
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Dead Bay Trail SOC? Compal la-b481p
    I have NEVER seen any bad Intel SOCs in the past few years. Not to say it can't happen, though.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      saw 1 that took lightning through the lan.it was a industrial sbc.
      • luke10050
        • Mar 2013
        • 209
        This laptop has been pretty abused, no liquid damage, though practically every port is mangled beyond recognition, none of them are shorted iirc, probably should check better. Just trying to fix it in my spare time
        My thought was the same, i've never seen Intel silicon fail, this is just behaving odd. Something did let a bit of smoke out once the 3v rail was connected, had a bit of a look but could not find any particularly ruined passive components. I'll probably just go around and look for weird behaviour. I've noticed already I don't have 0.65v but i"'m not sure if that's generated at the same time as the 1.35v for dram.
        All the s5 voltages are there minus rtc voltage (dead short, can't find anywhere it goes bar CPU.) And I don't have a board view file for this board. Just seems weird, I'll get there eventually or give up on the cheap board I guess.
        • luke10050
          • Mar 2013
          • 209
          okay, so i had a bit of a look, VR_ON (enables SoC VCC) is pulled low, seems to come from the embedded controller. however DDR_PWROK is at +1.35V, not sure what the go is to be honest. as i get DDR_PWROK but no VR_ON and no obvious damage on the PCB
          • double_DD
            How can I be sure that my EC chip is dead?
            by double_DD
            As the title suggests, how can I be sure that my EC chip is really dead?
            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
            03-12-2025, 07:47 AM
          • disorder
            ps5 edm-033 dead after hdmi/usb ports destroyed
            by disorder
            hello guys,
            i need help to repair a edm-033 ps2
            history : as always hdmi port and usb ports destroyed after unplugged
            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
            so i changed it
            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
            i don't see any projection of liquid metal on pcb.
            01-14-2025, 12:48 PM
          • Beton
            Finding a dead short component
            by Beton
            Hi guys!
            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
            I have a bench PSU and if I try to inject voltage the voltage...
            12-10-2021, 01:05 PM
          • zunasthegreat
            Chieftec GPS-450-AA with dead 20N60C3
            by zunasthegreat
            Hello everyone hope all doing well!
            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
            09-01-2024, 07:12 PM
          • FiguringITout
            MSI Raider GE75 - Not posting, probable dead CPU
            by FiguringITout
            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
            07-25-2024, 07:27 AM
