Trouble finding the shorted parts.
+ More Options
Posts
  • anthrax0987
    • May 2016
    • 24
    • Empty
    I was diagnosing a laptop with a shorted capacitor or mosfet.
    I cannot figure it out. The only weapon that I have is a analog multimeter "Sanwa" type.
    Laptop is complete black and no Indicator. Is there such a technique to check those capacitors, diode, MOSFET in a way that I can pinpoint the problem in a good amount of time.
    Is there a tutorial out here or and URL that you can share? or anything that becomes my resource?
  • inflex
    • Aug 2012
    • 545
    Re: Trouble finding the shorted parts.
    If the meter has a diode-test mode, then use that. Place +ve probe to the ground and see what you get at the various points on the board. 0.4V or greater usually isn't a short. Essentially the lower the reading in diode-mode, the more "shorted" it is.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • piernov
      • Jan 2016
      • 4439
      • France
      Warning: low resistance/voltage drop on CPU VCore or GPU VCore is usually not a short, NB/SB/PCH can have low readings too. Remove CPU if you can. When you check in resistance mode, you can only conclude those lines are shorted if you get something lower than 0.5-0.3ohm. However, you may still have a shorted cap when the reading is higher. Shorted caps can give a few ohms resistance, you won't be able to see that on a low voltage/high power line.
      • inflex
        • Aug 2012
        • 545
        Originally posted by piernov
        Warning: low resistance/voltage drop on CPU VCore or GPU VCore is usually not a short, NB/SB/PCH can have low readings too. ...
        That's good advice
        • anthrax0987
          • May 2016
          • 24
          • Empty
          I've done this I removed the processor. but what if its like an i3. some motherboards processor cant be remove.
          So it means that I need to take those capacitors one by one and test them. What I did is that I tried the continuity of my multi meter and the continuity is always equal to some capacitors.
          • sancheti81
            • May 2014
            • 191
            • India
            give supply 3v to 5v on dc socket and check if any cap is getting heated
            • rievax_60
              • May 2012
              • 897
              • australia
              What might look like a short to ground on the VBAT rail can sometimes be a shorted Buck regulator high side MOSFET. Any voltgae applied to the VBAT rail will be applied to what ever the regulator is powering, CPU, GPU.
              Dont apply much more than 1 volt.
              Most laptop designs have a protection that prevents the input protection MOSFETs from being turning on if there is a short on the VBAT rail, when voltage is applied to the DC socket.
              • tablet3rs
                • Aug 2013
                • 57
                • philippines
                kabayan,
                you might want to start on inductors, set the analog meter to x1 check both sides of inductor, check all the inductor, usually L or LP labeled in laptop board,
                might save you a lot of time in finding shorts,
                have you check the charger, charging port and the fuse right to the charging port?
                good luck
                ps got here example of mobo where youll find inductor if you dont have any idea what inductor looks like,
                and look for schematic of you mobo or boardview....
                [IMG][/IMG]
                • anthrax0987
                  • May 2016
                  • 24
                  • Empty
                  Originally posted by tablet3rs
                  kabayan,
                  [IMG][/IMG]
                  It's a coil bro right? The coil is shorted too. but some are not. and how can i supply a 5v power in my board, like what above you have said. he said that i must apply 3v or 5v then look for a heating part. are you working in SST Laptop?
                  • tablet3rs
                    • Aug 2013
                    • 57
                    • philippines
                    you must remove 1 pin of the inductor (coil) and find out which side is shorted or both are side shorted...
                    schematic is a must to be able to pin point what component(s) is shorted,
                    • mehtabbukhari
                      Lets help
                      • May 2016
                      • 26
                      • India
                      Please let us know your model no. or board id so that we can help you with the schematics.
                      • inflex
                        • Aug 2012
                        • 545
                        As a side note ( and I apologise for diverting the topic ), do you have access to the ASUS X550CC schem? I've tried many places, even tried laptopschematic, no luck. I can get the X550CV and other similars, but not the X550CC.
                        ... and back to our regular channel ...
                        • mehtabbukhari
                          Lets help
                          • May 2016
                          • 26
                          • India
                          Sorry, I don't have X550CC schematics.
                          • chestercc
                            Alienware M18x Shorted CPU Mosfet
                            by chestercc
                            I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                            I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                            Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                            07-16-2022, 06:05 AM
                          • mat2k
                            iMac 2017 PSU - shorted PFC mosfet
                            by mat2k
                            I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                            There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                            03-13-2025, 11:31 AM
                          • daemon123
                            MSI GTX-980ti shorted MOSFET on memory rail
                            by daemon123
                            Hi All,
                            I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                            What should be the next step. Kindly guide.
                            The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                            05-10-2023, 11:05 AM
                          • Jane
                            How do you test MOSFET in laptops ?
                            by Jane
                            I tried to use this method:
                            Testing an N-channel MOSFET:
                            Step 1: Discharge the Gate (turn off the MOSFET)
                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                            Step 2: Charge the Gate (turn on the MOSFET)
                            Now, place the red probe on the Gate (G) and the black probe on the
                            09-27-2024, 03:31 AM
                          • Reintar
                            Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
                            by Reintar
                            First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
                            One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
                            08-30-2024, 06:13 AM
