Trouble finding the shorted parts.
+ More Options
Posts
  • anthrax0987
    • May 2016
    • 24
    • Empty
    I was diagnosing a laptop with a shorted capacitor or mosfet.
    I cannot figure it out. The only weapon that I have is a analog multimeter "Sanwa" type.
    Laptop is complete black and no Indicator. Is there such a technique to check those capacitors, diode, MOSFET in a way that I can pinpoint the problem in a good amount of time.
    Is there a tutorial out here or and URL that you can share? or anything that becomes my resource?
  • inflex
    • Aug 2012
    • 544
    Re: Trouble finding the shorted parts.
    If the meter has a diode-test mode, then use that. Place +ve probe to the ground and see what you get at the various points on the board. 0.4V or greater usually isn't a short. Essentially the lower the reading in diode-mode, the more "shorted" it is.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • piernov
      • Jan 2016
      • 4435
      • France
      Warning: low resistance/voltage drop on CPU VCore or GPU VCore is usually not a short, NB/SB/PCH can have low readings too. Remove CPU if you can. When you check in resistance mode, you can only conclude those lines are shorted if you get something lower than 0.5-0.3ohm. However, you may still have a shorted cap when the reading is higher. Shorted caps can give a few ohms resistance, you won't be able to see that on a low voltage/high power line.
      • inflex
        • Aug 2012
        • 544
        Originally posted by piernov
        Warning: low resistance/voltage drop on CPU VCore or GPU VCore is usually not a short, NB/SB/PCH can have low readings too. ...
        That's good advice
        • anthrax0987
          • May 2016
          • 24
          • Empty
          I've done this I removed the processor. but what if its like an i3. some motherboards processor cant be remove.
          So it means that I need to take those capacitors one by one and test them. What I did is that I tried the continuity of my multi meter and the continuity is always equal to some capacitors.
          • sancheti81
            • May 2014
            • 191
            • India
            give supply 3v to 5v on dc socket and check if any cap is getting heated
            • rievax_60
              • May 2012
              • 897
              • australia
              What might look like a short to ground on the VBAT rail can sometimes be a shorted Buck regulator high side MOSFET. Any voltgae applied to the VBAT rail will be applied to what ever the regulator is powering, CPU, GPU.
              Dont apply much more than 1 volt.
              Most laptop designs have a protection that prevents the input protection MOSFETs from being turning on if there is a short on the VBAT rail, when voltage is applied to the DC socket.
              • tablet3rs
                • Aug 2013
                • 57
                • philippines
                kabayan,
                you might want to start on inductors, set the analog meter to x1 check both sides of inductor, check all the inductor, usually L or LP labeled in laptop board,
                might save you a lot of time in finding shorts,
                have you check the charger, charging port and the fuse right to the charging port?
                good luck
                ps got here example of mobo where youll find inductor if you dont have any idea what inductor looks like,
                and look for schematic of you mobo or boardview....
                [IMG][/IMG]
                • anthrax0987
                  • May 2016
                  • 24
                  • Empty
                  Originally posted by tablet3rs
                  kabayan,
                  [IMG][/IMG]
                  It's a coil bro right? The coil is shorted too. but some are not. and how can i supply a 5v power in my board, like what above you have said. he said that i must apply 3v or 5v then look for a heating part. are you working in SST Laptop?
                  • tablet3rs
                    • Aug 2013
                    • 57
                    • philippines
                    you must remove 1 pin of the inductor (coil) and find out which side is shorted or both are side shorted...
                    schematic is a must to be able to pin point what component(s) is shorted,
                    • mehtabbukhari
                      Lets help
                      • May 2016
                      • 26
                      • India
                      Please let us know your model no. or board id so that we can help you with the schematics.
                      • inflex
                        • Aug 2012
                        • 544
                        As a side note ( and I apologise for diverting the topic ), do you have access to the ASUS X550CC schem? I've tried many places, even tried laptopschematic, no luck. I can get the X550CV and other similars, but not the X550CC.
                        ... and back to our regular channel ...
                        • mehtabbukhari
                          Lets help
                          • May 2016
                          • 26
                          • India
                          Sorry, I don't have X550CC schematics.
                          • reessi
                            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                            by reessi
                            Hello:
                            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                            I started on the ACER:
                            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                            10-29-2024, 11:31 AM
                          • modtool
                            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                            by modtool
                            Hi to all,
                            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                            04-01-2025, 08:22 AM
                          • BalkanBoy
                            Dead Razer Blade 14 2022, shorted CPU?
                            by BalkanBoy
                            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                            I removed coil and injected 0.7V, it draw around...
                            09-27-2024, 12:44 PM
                          • barry101
                            Apple 820-3662 VCore shorted to ground.
                            by barry101
                            Hi, Would appreciate some help.
                            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                            Get charger light but no fan spin or chime. No liquid damage.
                            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                            06-24-2025, 07:34 AM
                          • guizmo1967
                            Dell Latitude 5501 LA-H181P shorted power rail
                            by guizmo1967
                            This is my problem:
                            Laptop: Dell Latitude 5501
                            Motherboard: EDC51 LA-H181P
                            I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                            I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                            I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                            I injected +1.05V - 2A...
                            07-25-2023, 06:56 PM
