Low-voltage Capacitor Replacement in Laptops
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    I have got a general question about capacitor replacement which I faced in Laptop motherboards.
    Let us consider a smd ceramic capacitor connected to a 1.8-volt power or data or clock line. The capacitor is: 4.7uF_0603_6.3V
    The capacitor is supposed to work with low voltages such as 1.8v or 0.8v.
    Now, what will change in the circuit or laptop function if I replace that capacitor with a high-voltage smd ceramic capacitor such as: 4.7uF_0603_50V ?
    Does it matter whether it is connected to a power, data, or clock line?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Low-voltage Capacitor Replacement in Laptops
    Does a 6.3v capacitor have better charging and discharging capabilities under low-voltages and high frequencies compared to a 50v capacitor of the same capacity?
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • artvandalai
      Where can I get compatible capacitor for replacement?
      by artvandalai
      Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
      12-28-2024, 10:15 AM
    • NuclearSpartan
      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
      by NuclearSpartan
      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
      I don't see any other visible damage anywhere else on the board....
      11-14-2024, 02:32 PM
    • r2digital
      klipsch kda-500 amplifier suitable power supply capacitor replacement ?
      by r2digital
      I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
      04-18-2024, 03:50 PM
    • rwkish
      Discontinued Capacitor looking for Replacement
      by rwkish
      Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
      08-18-2024, 06:54 PM
