hp g6 dar013mb6e1 shutdown problem
    hi friends need ur help i have hp pavilion g6 dar013mb6e1 rev e intel graphics laptop
    i face shoutdown problem within 30 minute
    i need clear me region bios bin file
    Re: hp g6 dar013mb6e1 shutdown problem
    Hi my friend , try this:
    (Do not forget to take backup from current bios)
    good luck
      hi tiak ur bios does not support system
      i think its different pls upload exact bios with clean me region
        read your old bios and post here
        you can also use search
        https://www.badcaps.net/forum/search...archid=6679327
        Im Back... sort of...
          Hi mitu_sharma ,sorry but it was dump file from "HP G6 DA0R13MB6E1 QUANTA R13 REV. E-intel" ,what is your laptop problem? and what happened after writing this file?
          Such as ala_borbe said,read your old bios and post here or tell us what is your old bios bid?
          good luck
            old bios backup here
            hi friends
            as i told u in first post the laptop shutdown exact 28 to 29 minute
            tiak with ur bios when i turn on laptop only single cursor blink left side upper corner
              you try this
                try with this
                  i tried all of this bios but still same
                  exact timing of shutdown is 29 minute & 49 sec
                  what could cause this help
                    I don't think it is BIOS problem, because system starts well.
                    Did you checked temperature?
                      Hi, I agree with dspok
                      check temperature , and also test with a game or movie ,see it shutdown earlier or not?
                        nop
                        after 30 min
                        its CPU not compatible with PCH
                          you can trust me on this , chek wich is your PCH , and go to google and chek PCH model XXX cpu compatibility , and then chek if the cpu you're using is on the acceptance list
                            hey guys i was not in the city
                            sorry for interruptions.....
                            again i repeat the shutdown topic of pavilion g6
                            (sr0dn) core i3 cpu i am using is in acceptance list of pch.
                              guys pls tell me how to check temperature of pch hm65 ,
                              if any tool available pls upload.
                                hm65 its suposed to getonly warm , if its hot , then its not ok .
                                have you cheked correctly on PCH support list if the exact cpu model is accepted ?
                                just in case try with another compatible CPU , to be sure !!!!
                                if not , wich is the revision of your motherboard ?
                                its its rev E
                                use this bios
                                  hi mitu change your processor dualcoe, i think it willbe work
                                    please check if it over heats or you can also change the processor and see
