Tosh Sattelite Pro C660 Screen divided in 3
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello guys,
    i have here a C660-13C, PSCORE-00300EFR with a wierd symptom, the main screen is divided on 3 parts (check photo)?
    When received, i was getting a black screen, flashed main and ec, and pc turned ON.
    First time the screen was fine, after a second reboot, i got the divided screen, reflowed BGA, this machine is uma, only HD graphics from Core I3 ship.
    Is this a lcd screen problem or GPU related ?
    For 2 ou 3 times it rebooted fine, no divided screen
    It works fine on external (VGA)
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: Tosh Sattelite Pro C660 Screen divided in 3
    Just an idee.
    I would gamble on the bios, being in conflict with the hardware (screen). If nothing else has changed. This is typical look, when you use a screen from a different brand. For example when you use a Hp screen in a Dell.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Screen is original (come with laptop).
      I also updated the bios, using the bios update from Toshiba website, used the serial number to get the right/good bios.
      I still have a doubt if the lcd is faulty ?
      • JaroTech
        • Mar 2015
        • 351
        Hi, I would say the problem is with your screen.
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          Yeah, i need to test another lcd to be sure !
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            You're right, that's a good way, because you didn't see the image before you change the bios.
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              sometimes 1% this problem causes bios .....you must to flash the bios and use another ic and flash it.
              - the screen
              -50% la nape qui relie l'ecran with the mother .
              -socket of nape lvds .
              -chip vga
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                - the screen
                -chip vga
                I have here a similar Sattelite ready to dispatch, and now i need to dismantle it again, oh dear.
                I will first test the hole Lcd display it's own with cable, this one is 100% working.
                I never saw i screen divided like this before, Lol we learn everyday ...
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  I confirm that the problem is the LCD display, just tested another display using same ldvs cable and picture is not divided.
                  • pcnetch
                    • Aug 2013
                    • 125
                    • Sri Lanka
                    Change LCD Display. Then ok. I have faced several times
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      Yeah, this is what i've done will know next time !
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
                      • ipatch
                        ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                        by ipatch
                        i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                        08-24-2024, 02:36 PM
